Home > Maintenance & Mods (L322) > tow bar is bolted and welded..!!!
Page 2 of 3 <123>
Big Boy R44ROV
IMHO No Range Rover worthy of the name should be without a tow bar. Whether it's used or not......
Post #213827 3rd Oct 2013 10:16am
damn , i need to buy one now.. Neutral ... - .- -.
Post #213829 3rd Oct 2013 10:20am
Dolphinboy
Stan I got a good one (as new) 2005 on with new removable hook. Let me know if u r interested. Thumbs Up
Post #213838 3rd Oct 2013 11:57am
Thud cheers James...i need keep my mouth shut Laughing
can you pm me with a price to see whether i actually need it or not .. ... - .- -.
Post #213839 3rd Oct 2013 12:06pm
Big Boy R44ROV
Oh Stan. Surely you're not going to begrudge your beloved FF the tow bar it craves.... Rolling with laughter
Post #213840 3rd Oct 2013 12:17pm
shame we aint got a 'middle finger' emoticon... Laughing ... - .- -.
Post #213841 3rd Oct 2013 12:19pm
This one do?
Post #213843 3rd Oct 2013 12:24pm
Big Boy R44ROV
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Well I think you have now made the justification for one !
Post #213844 3rd Oct 2013 12:26pm
Post #213845 3rd Oct 2013 12:34pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Hi - just to say you can remove that entire armature as that is supplied by Westfalia when fitting their detachable towbar.
To then replace your exhaust hanger and towing eye you need part number KPU000032 from Landrover which is strangely called REINFORCEMENT (they are only about £40 the pair) then you have a perfectly standard Range Rover with no towbar - the REINFORCEMENT pieces are also made by Westfalia as they are labelled that.
The thick bar which runs behind and below the bumper on the armature for the towbar is there to spread the load of the trailer - its not there for crash protection so you wouldn't invalidate your insurance as its wasn't present on Range Rovers leavng the factory without the detach towbar specified.
Hope that helps Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #213951 3rd Oct 2013 9:15pm
biffa
2009 Range Rover Vogue TDV8 Rimini Red
Towbar question
Hi, can I ask/add to this please.
My rear crossmemder does not look like the one in the earlier picture. I have a 2009 Vogue. I want to fit a towbar, but I do not have the central square looking hole that wraps around the armature, that would receive the tow bar?
Can anyone tell me if this is normal? I had a sport before, which did have the standard square hole, ready for a tow bar? I have the Westfalia P/N from the arnature: 323 070 600 003. I have googled this and nothing comes up.
Any help will be appreciated.
Thanks
Post #219151 27th Oct 2013 8:14pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Removable Hook?
Would that be the Abu Hamza option?? Rolling with laughter
Post #219156 27th Oct 2013 8:29pm
Biffa, if you can put up a pic. Thumbs Up
otherwise:
the RRS and Disco tow balls are completely different from the FFRR. The RRS is made by Thule and the FF is by Westfalia
if you have a westfalia armature on the car it should be ready to accept either the detachable unit or the adjustable farmers hitch.
(Ajay(uk)'s pic)
this is a pic of an armature with the receiver for the detachable bar bolted on. In the pic below the part i think you need is the grey bit!
the armature you have should be the part that bolts into.
have a look on the bay of fleas for one or keep an eye out on here they come up occasionally.... There is nothing that can't be fixed with a hammer😜😜
Post #219159 27th Oct 2013 8:42pm
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
I had fitted the tow bar armature to my last FFRR (2006 TD6) and happen to have the two brackets that were originally fitted to the car. They incorporate the exhaust hangers and the towing eye. If anyone wants them, they are welcome to have FOC if they can sort out collection/courier from Larne in Nor'n Ireland.
I also happen to have a set of used front discs from the same vehicle. They have a bit of wear, but are warp, crack and serious grooving free. Again FOC subject to collection or courier. Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #219189 27th Oct 2013 9:42pm
biffa
otherwise:
(Ajay(uk)'s pic)
Thanks. But mine does not look like this to start with. I have the Westfalia P/N 323 070 600 003.
There is no where to recive the tow bar. Do I need to change the armature?
I will try to add a picture again Smile
Post #219205 27th Oct 2013 10:51pm
Page 2 of 3 <123>
