Home > Maintenance & Mods (L322) > Vote - 4 x Headlight Conversions - Which one? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
re image number 4 during darkness, you wont actually be driving around like that ,you'll have dipped beams on which will engulf the drls, [unless they switch off when headlights on].....
27th Oct 2013 5:46pm |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
Image 1 for me like Googsy and Props lights
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 |
Option 5 for me.
27th Oct 2013 8:12pm |
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 |
Images of my previous FFRR TD6 Vogue SE, the LED halos cost £53 all in including DRL relays for both headlights & about 21/2 hours work each side. Passed MOT no problem.
27th Oct 2013 8:58pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Yep all straight forward hardest part is making sure you don't bake the lights too long in the oven .I did not use relays but tapped into sidelights. I would go with the above option Present :2008 TDV8 HSE
27th Oct 2013 9:17pm |
We use an AGA, some exact temperature control was not an option. Used a heat gun instead and that worked okay. Suspect doing as Googsy did using an oven would be quicker, potentially less messy.
27th Oct 2013 9:27pm |
I sourced directly from China, will try and dig out the old invoice to identify the company. I bought all the halos, 2 of each size, from the one company to ensure uniformity of brightness, colour etc. The relays I mounted and spliced into the existing wiring inside each headlight and configured to come on with the ignition & extinguish when the headlights were turned on. I changed my sidelight bulbs to matching colour LEDS. No separate switch is required with this setup and it is completely legal, resulting in ignition on - Halos on, Sidelights on - Halos on, Side & front fogs - halos on, headlights & sidelights - halos off. Main beam - halos off.
28th Oct 2013 7:52am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
I'd go for op 1, but then the stock looks just great in any form of FF....then there had to be an other option ....number 5
28th Oct 2013 9:52am |
Can't find invoice as it was well over a year ago that I did this mod. From memory the company was called something like hnb.com or hnbshop.com? Should've been old enough to know better...doh! Current 2010 5.0 SC Autobiography Previous 2006 TD6 Vogue SE Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10) |
28th Oct 2013 10:32am |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
pld118, I got my halo kit from forum member Jr-auto-electrics so it might be worth pm'ing him. |
28th Oct 2013 11:54am |
Thanks for all of the very helpful replies to date:
29th Oct 2013 12:19am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
That's the kind of response that would make me buy from them. Confident, helpful, factual. Not pushy or arrogant.
29th Oct 2013 6:58am |
@Bellini -
29th Oct 2013 7:11am |
re fitting, put some thin cardboard or heavy duty paper on the bumper where the headlight is, its easy to scratch it as you wiggle the headlight out..
29th Oct 2013 8:15am |
