![]() | Home > Maintenance & Mods (L322) > my new carx project almost done |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
And another camera bit of software that also links in to gps to record co-ord, speed, direction, time , height above sea level etc.
hi, the lead comes with the video converter so thats that one covered |
Ok - Audio leads installed and tested with a tape in. - Sorted. |
hi mate, look for this plug in the boot,it will have live feed,i-bus and ground..you can see my red,black and yellow wires the forth wire will be your switch on pin 17.....
AV adapter and resler interface have arrived today in the post just in time for my 4 days off |
Carx - DONE!
hi, do you get the title of the song come up in your dash message window when selected..i do! V8 facelift Range Rover Autobiography 22" wheels.
Yes! Awesome! Just been out for a run to my Dads and had the laptop in doing its stuff as a trial for the Hols.
did you get the artist and song name come up in the message window of your dash..looking now for a good quality cam if you know of any..could not down load that software the link was dead.. V8 facelift Range Rover Autobiography 22" wheels.
Yep song title and Artist appears on the OBC dash display |
hi mate, i made a video cable up out of some ox,free and a pair of gold rca to the right length. just got some 2010 switches to see if i can swap them over and move the contol of carx to the steering wheel.
At the mo I'm only using Carx on trials and so I swap the carx video with the reverse camera when testing. Pin 17 is still fed from both the resler interface and also the switched earth from the reverse camera relay. At the worst when carx closes and resler kills the video feed I end up seeing the desktop screen when reverse is selected. |
so do you have both the car x and reversing cam in a two into one splitter on the video , if so what happens if you are using car x and the select reverse...thinking about it i have a 12v powered 2 into 1 splitter someware that would do change the sorce cleanly.. V8 facelift Range Rover Autobiography 22" wheels.
No I manually swap the plugs at the mo.
