Home > Technical (L322) > Need a gearbox specialist ideally near Essex but flexible.
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Yesterday the car went into transmission failure limp mode on the M25. Probably the torque converter, but with 136k miles on the clock the gearbox could probably use a refurb too.
Anyone with experience of a good, reliable specialist in the Essex/London/Homecounties area? Might consider further afield if worth it as I know it will be an expensive job, car would need to be recovered by them.
I see that there is lots of talk on a Sonnax valve block upgrade and the need to also replace the oil cooler.
Any advice or help greatly appreciated. Crying or Very sad
So far I have seen the following companies recommended in other threads, but not too sure of costs or if they are still any good.
A1 Premier Transmissions - Biggleswade
Midland Automatic Transmissions - Kettering
Here are some other companies I have found online but not sure if they are any good.
The Reconditioned Gearbox Company - Twickenham - Offer 2 year warranty
A1 Engines - Rainham Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #218642 25th Oct 2013 12:18pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi, had my gearbox done around 3 weeks ago , 3.0L TDV6 (90,000 miles - know point of failure apparently on the GM boxes) , but obviously I'm up north, but I can at least give you an idea of cost. I paid £2100 and for this, I got a full rebuild of the torque converter , clutch plate etc with the LR upgraded parts and also got a 12,000 mile /1yr warranty (this was at GearTorque in West Houghton, Lancs and is a 2 day turnaround as they always have the parts in stock). Have to take the car back at 1000 miles /1 month for them to check for leaks etc. The other company I looked at was in Leyland, Lancs and charged £2300 for same as above, but they upgrade the oil cooler and if they remove and fit it, they give a 24K mile / 2yr warranty (else 1yr if you ship them the gearbox for rebuild) , however, their specialist was on long term leave hence could not use them. Main dealer could exchange gearbox for £4500 fitted !!! So that was not a viable option.
I did notice a dramatic change in the box when I got it back , the upshift /downshift between gears is very smooth now , I had not noticed over a long period how sluggish the upshift had become , the first signs of the upcoming failure in retrospect.
Hope this info helps. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #218705 25th Oct 2013 5:37pm
alib123
Hi, did you have any joy with the rebuild and could you recommend a company in essex, cheers
Post #232001 30th Dec 2013 3:47pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
You have RST landrover in Mersea Essex everyone rates about them on here. It's just a garage though so I'm guessing they wouldn't be able to refurb more likely just refit. Bushy
2003 RR Vogue Monté Carlo Blue
Post #232097 31st Dec 2013 11:56am
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
This might be a bit late but the transmission shop on canvy island is good I have the address if you need it
Post #241406 9th Feb 2014 5:43pm
Cloned earl
England 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Recently had my repaired by ATS on Mersea Island, The guy really know's his stuff, although can be a bit pricey.. Previous LR's
Series III x2 SWB
Defender V8 90
Range Rover Classic V8 3.9 x2
Range Rover Classic V8 3.5 efi
Defender TDI 300 x2 90/110
Freelander V6
Defender TD5 110
Discovery II V8 LPG
Post #241593 10th Feb 2014 10:39am
