![]() | Home > Maintenance & Mods (L322) > Upgrade - 2010MY Headlight Solution? |
Hi,
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
RR, these aren't new lights, but conversions to make 2005-2009 lights LOOK like the later 2010- lights. |
Must be this lot: http://www.prestigevehiclesolutions.com/php/modifications.php |
Firm quoted by Gary appears to be based in Wrexham.
@RR2008HSE - Thoughts noted, thanks. I've also seen the spirited 'facelift' thread |
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...1e8073e750
My bad sorry, this is on their site: http://www.autoprestigecars.co.uk/accessories.asp
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
i gather you would like some kind of drl that isnt to much 'in your face' Ryan...as you might know i have converted my fogs into smd drls and they dont look to bad, also you might like to know that the IIDTool has the ability to switch on your main beams to 40 or 60% brightness as drls and changing the bulbs to white type ones improves the look even more..
Thanks Stan/ didn't know that about the IID which is also interesting. The round sidelights on ours look almost yellow when illuminated, in contrast to the xenon main beam and that contrast is not very good looking, the standard yellow looking one appearing cheap IMO (presume you mean that these existing headlight unit bulbs can simply be changed to whiten/ freshen things and DRL opportunities are given via the IID)?
the front side lights can be very easily changed to smds which will compliment the xenons very well...the main beam h7 bulbs can also be changed easily to a white colour halogen for about £8 for the pair..
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
Ryan, as Stan says, the side light bulbs are easily replaced with LED ones which get rid of the yellowish tinge as compared to the Xenon headlights.
Thanks Stan & alanm... Yes, if having the existing lights modified, I was thinking about adding Halo/LED/DRL to the existing lights as opposed to buying an off the shelf replacement light unit (would not want to lose any functions) |
Just telephoned the Bradford firm that my OP was about. Wasn't convinced based on his telephone manner. It is £400. His Speech, a little contrary to the advert, was that 'you won't exactly get a 2010 look'. The chap was vague, seemed disinterested and said that they fit ringed lights, 'about 5 or 6 lights' around the headlight (looks like 6 on the below picture). He says they do put the clear indicator strip in place of the orange and then you just put your old headlight unit back in the car and the ringed lights work via the sidelights being switched on.
Sounds like he's talked himself out of a potential sale!
