Home > For Sale & Wanted > Pre Heater remote - wanted
nbunney
Any one got one for sale?
If not, do I need to go to the dealer?
Do I need anything else, wiring kit etc?
All help in getting a remote and getting it up and running would be great, thanks.
Post #2179 8th Jan 2009 11:30pm
Larry
England 2006 Range Rover SE Td6 Java Black
Ebay. They seem to crop up there regularly for a fraction of the dealer cost.
One ebay item claimed the dealer price was £187! Shocked No idea if this is correct, but wouldn't be surprised (maybe someone who's bought one can confirm).
Not sure what you have to do to program them (probably another £60 to the dealer!) or do you need to have the full Vogue software upgrade to have to screen controls for it?
Have a look at Ebay item number 150319986920. Runs until 15th jan. Bit steep for a starting price though.
Post #2183 9th Jan 2009 8:52am
nbunney
Larry,
Thanks for that.
I do not need the software upgrade, as I have a Vogue SE, I just want the remote function as the Mrs will have it on all the time. This way it can be on only when it's cold and the doors have frozen up.
Post #2200 9th Jan 2009 3:26pm
You are certain that your car has the heater yes?
I can't recall when it became standard. Discovery 4 HSE
Post #2201 9th Jan 2009 4:39pm
nbunney
It's in the touch screen options, so I'm guessing so, but I will check this weekend to see if I have the box of tricks under the nearside bumper.
Post #2202 9th Jan 2009 5:18pm
So FBH'S dont come as standard on diesel's , how much do the cost if retro fitted
Post #2204 9th Jan 2009 5:22pm
Sorry to dampen the flames but the remote won't work without the receiver and that is part of the TV receiver which is why it has such fantastic range , without changing the TV module it's no go I'm afraid. Big Cry 2008 MY Supercharged
Post #2205 9th Jan 2009 5:49pm
nbunney
If I carn't be sure I'll get my dealer to check when it goes in for the common rear washer problem.
Also had the adaptive headlight warning come on today, then it went out later on and the Mrs didn't even have the lights on.
Good old electrical gremlins.
Post #2206 9th Jan 2009 5:50pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
sorry to hi jack your thread but is there a fix for the rear washer then as mine is a tiddy bit poor Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #2210 9th Jan 2009 6:33pm
Larry
Is this why it only comes with the Vogue upwards? I hadn't heard this and assumed that the heater worked independently of the rest of the car, hence the separate remote.
Post #2315 14th Jan 2009 3:35pm
The fuel burning heather in the Range Rover is different to the FBH in the D3 or RRS in that it can do two jobs as a factory fit,first it is there to heat up the diesel engine on cold mornings to improve efficiency and uniquely by using the touch screen to control it can be used as a parking heater or timed heater. The Disco based vehicles have a FBH but it cant be controlled by the vehicle(a webasto timer can be fitted but it can't control the heating fan or ducts making it mostly useless)The remote control is another option that can be fitted but as we have discussed that means some expensive parts. Big Cry :if not all ready fitted. Thumbs Up
Now I can sit back and waite for all the D3 and RRS owners with a webasto timers to jump in and tell me they think its grate their fans don't work. Whistle 2008 MY Supercharged
Post #2317 14th Jan 2009 4:14pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Axle with you the crap FBH was one of the many reasons I changed to a FFRR from a D3 made sure several times it had the remote Thumbs Up
Post #2320 14th Jan 2009 5:46pm
Larry
Mine hasn't got the controls on the touch screen or the remote. Not too bothered as the FBH has been a pure pain in the A55 due to a fault leading to a smoke screen everytime it kicks in.
I have probably missed the thread, but what do you need to enable the remote on cars without it fitted? I presume it's a little more than a software upgrade.
Post #2333 15th Jan 2009 8:12am
You need a Vogue model with TV fitted Larry. Discovery 4 HSE
Post #2335 15th Jan 2009 12:12pm
Chippy Minton
United Kingdom 2010 Range Rover Autobiography TDV8 Java Black
Larry
Hope my post doesn't confuse things further
I have a 55 plate HSE which has the FBH. I don't have either the Navigation or the TV fitted, however I do have the Touch Screen and the FBH is remote controlled, handy on the cold mornings.
I have a spare remote control if you're still looking for one give me a shout. It does need to be programmed in by the dealer though.
Post #2340 15th Jan 2009 1:23pm
