Home > Maintenance & Mods (L322) > Couple of Q's on 2006 conversion
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
In the middle of said conversion at the moment and have a question about the headlamp mounting. The 2006 Xenons I have to fit have the vertical tabs at the top - however the lights from my 2004 that I removed were fixed horizontally with flat tabs on top. How do I fit the new lights? I cant find any pics on this or other RR.net sites to show that bit.
thanks
Simon "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #218072 22nd Oct 2013 2:12pm
according to the how to in the wiki , you need some headlight mounting assemblies,
http://www.fullfatrr.com/forum/viewtopic.p...8707db8222 ... - .- -.
Post #218073 22nd Oct 2013 2:17pm
MrP
I have those brackets but they are steel brackets next to the rad and dont appear to have anything to do with fixing the top of the lights.....
Looks like I need a couple of 90 degree brackets to hold the top two mounting points but cant see any pics on rave or elsewhere to confirm that. "On first name terms with my local Dealer......now."
Post #218077 22nd Oct 2013 2:22pm
Googsy
Just guessing but do you need the new type wing brackets due to light being different shape. These fit to the inner wing and have holes for fixing of light .I had to replace these doing 2010 conversion so its likely these need replaced ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #218084 22nd Oct 2013 3:16pm
these are a couple of pics of my lights [2008]
does this help any?
Post #218087 22nd Oct 2013 3:23pm
MrP
oooow that looks exactly what I need - can anyone provide a part number for the top parts? or even a pic from rave so I can get the parts locally?
Thanks Stan "On first name terms with my local Dealer......now."
Post #218090 22nd Oct 2013 3:39pm
you could try microcat for the part numbers , links in the wiki. ... - .- -.
Post #218091 22nd Oct 2013 3:42pm
MrP
Grrrr, trying Microcat and they have loads of blown up drawings but none have the bits I need. "On first name terms with my local Dealer......now."
Post #218097 22nd Oct 2013 4:33pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I hate to be the bearer of bad news but I don't think you can by those parts separately.
They come with the lights.
Where did you get the lights from?
Post #218101 22nd Oct 2013 4:53pm
is it this part you need,ASW760090/80 [new part number is LR011566/65]
Post #218103 22nd Oct 2013 4:55pm
i think you need to talk to the man that knows everything about conversions, CAM - TECH - CRAIG...... ... - .- -.
Post #218104 22nd Oct 2013 5:04pm
MrP
Thanks Stan but no thats not the bit I need - I will PM Craig and may make up a bracket for now.
Thanks "On first name terms with my local Dealer......now."
Post #218118 22nd Oct 2013 6:02pm
Whistle Whistle Whistle Thumbs Up
Post #218126 22nd Oct 2013 8:01pm
paneldamage
I wonder if this plastic mounting piece is available separately? A guy bought a broken headlight off me just to get his hands on this bit......sorry, just seen Paul's post - what he said.
Post #218152 22nd Oct 2013 11:21pm
