Home > Technical (L322) > Air con Pump |
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 |
Two things to be aware of, first you would need to properly purge the AC circuit of refrigerant before disconnecting any pipe work and the second is ensuring the AC pump drive belt does not also drive any other ancillary device e.g. Water pump, Power steering pump and or alternator. If it does the belt will be too long when your AC pump is off the car. Should've been old enough to know better...doh!
22nd Oct 2013 3:18am |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 |
It's a separate belt mate as there isn't one on there at the moment. |
22nd Oct 2013 3:23am |
Then, once the system is purged of refrigerant, you should be good to go Should've been old enough to know better...doh!
22nd Oct 2013 3:25am |
Thank you for your advice squire. Much appreciated!!
22nd Oct 2013 3:34am |
Quick Fit or some Halfords can do it & if you sweet talk them by promising them you'll get them to recharge your system, they may wave a charge. If neither of those options are nearby, then a mobile AC service is likely your best bet. Should've been old enough to know better...doh!
22nd Oct 2013 3:38am |
Cheers for the advice B9er. |
22nd Oct 2013 3:41am |
Your welcome Paul271, good luck in solving you leak conundrum Should've been old enough to know better...doh!
22nd Oct 2013 3:43am |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Perhaps is this one correct: ??? http://www.ebay.de/itm/Klimakompressor-BMW...3367b4e332 L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
22nd Oct 2013 6:08am |
If you drive with the AC lines open, be sure to seal them properly (lots of duct tape, for instance). You do not want any additional moisture in your AC...
22nd Oct 2013 6:25am |
I'll double check meerbusch thank you.
22nd Oct 2013 10:05am |
Nipped in to Halfords today and they de-gassed my Air con so i'll tackle removing it tomorrow! Should be fun!! |
23rd Oct 2013 8:09pm |
So far, so good hope it all continues in the same vein Should've been old enough to know better...doh!
23rd Oct 2013 9:10pm |
Me too mate!! Took in to my Indy today and they agreed the pump needs to come out to find the leak. |
23rd Oct 2013 9:19pm |
Well it was a pretty straight forward process! Although there was one sphincter twitching moment when I went to start the Rangie after I'd finished and it wouldn't even turn over!!!
24th Oct 2013 6:29pm |
