Home > In Car Electronics (L322) > Iphone 4 cradle?
Have found my old iphone 4 cradle from my 5series,
where is it supposed to go? dont seem to have a hole for it. There is nothing that can't be fixed with a hammer😜😜
Post #131472 16th Jul 2012 7:18pm
daveo
lets see a photo of it... V8 facelift Range Rover Autobiography 22" wheels.
Post #131474 16th Jul 2012 7:30pm
sorry about the quality There is nothing that can't be fixed with a hammer😜😜
Post #131493 16th Jul 2012 7:58pm
doesnt that go into the center arm rest? ... - .- -.
Post #131496 16th Jul 2012 7:59pm
it physically fits in the top cubby, but i dont have any wiring in there, does anyone?
the connections are on the bottom, in the BM it snaps into position, and will click in and out so it can be easily changed for other units. the lugs at the end locate in 2 holes and the other end clicks down with a gentle press. to remove in the BM you simply press a button and it releases.
dont know if there is enough depth in the top cubby without modification, as the location of the inputs to the cradle are in a position where they come into contact with the bottom of the tray. The place where the wiring for the RR would fit appears to be further forwards.
Hope this helps.
This is the same BMW part as listed earlier. There is nothing that can't be fixed with a hammer😜😜
Post #131500 16th Jul 2012 8:08pm
daveo
i have the bmw cradle in my console and at the moment it has the 3gs in there, it looks like it would go in to my cradle, by the way i had to rewire my cradle..
would be interested in it if you dont use it any more... V8 facelift Range Rover Autobiography 22" wheels.
Post #131501 16th Jul 2012 8:12pm
PM me address and something for postage by pp and ill post it down. Never used it in the 5 series tbh as i have a case on the phone and it meant removing that every time i wanted to use it. There is nothing that can't be fixed with a hammer😜😜
Post #131504 16th Jul 2012 8:17pm
grancharly
United States 2006 Range Rover Supercharged Supercharged Zambezi Silver
That;s the part I thought could work. BTW my RR (US) has a wiring with a small connector for the Nokia cradle and I don't know if that works with the BMW cradle described.
Question
Post #131528 17th Jul 2012 3:17am
DaveU
United Kingdom 2008 Range Rover Vogue SE Supercharged Stornoway Grey
I've got an iphone 4. To be honest the bluetooth works perfectly in my 07 S/C so i've never even considered a cradle. Reception on the phone is fine and never had any problems with it. If charging is an issue then a £5 cable to charge from the cig lighter would do the trick. Thumbs Up
Post #131864 18th Jul 2012 4:57pm
MrSkill
Hi Daveo can you provide any more information on what you had to re-wire?
Post #217417 18th Oct 2013 4:52pm
