Home > Maintenance & Mods (L322) > L322 TD6 GM Auto Panick measure or preventative maintenance
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
(I first posted this thread elsewhere in Nov 2012)
Having invested a thick wedge in my new toy (88k mile 53 plate TD6 L322) and due to me planning on keeping the car (as I did my Soft dash) for apprx 5 years I have decided the following
I will be very shortly having a new torque convertor fitted
I have no current issues with the gearbox or gearchange but at 88k it wont be long before "issues arise"
Whilst reading previous threads and the excellent gearbox strip article linked to by others it appears to me the weak link is the plates within the convertor
My theory is that the oil pump draws in the oil through the filter and then into the TC which then pressurises the oil within the gearbox and valve system and oil cooler so should or more importantly WHEN the TC fails it dumps its swarf under pressure into the workings of the gearbox and as the box is not longer protected by the filter (after the TC) major failure is guaranteed.
So my plan is to have fitted a new TC, filter, cooler and a full strip, clean, inspect and rebuild of the gearbox - fill up with correct spec Texaco Texamatic 7045E oil BEFORE anything fails !!!
Have contacted VMTP in Cannock regarding the work to be carried out as a drive in - drive out service with them reporting back to me once box is stripped.
I run my own small MOT Service and repair business and VMTP have on previous occasions been no problem whatsoever to deal with and I have had no issues with work carried out by them for me.
Sorry meant to add that I will be regularly towing my track car all over the country and want to reduce where possible any risk of failure when out on the road.
OK - 1st Update
Driven to VMTP - had a long chat with Nigel and made him aware of my reasons for new TC, new gen LR oil cooller, strip, clean and rebuild
He says he has seen many RR Auto boxes eat themselves and has no problems with what I want to achieve
One thing they were not happy with though was the quality of my gearbox oil filter and I have subsequently swapped the item for a genuine LR item
They said they have seen non-gen filters collapse under high flow as no internal supports inbetween the filter element - £117.00 + vat gen LR Sad £55.00 inc pattern part
Box will soon be removed stripped and I am going to inspect the stripped box tomorrow.
Just been to VMTP to inspect the stripped gearbox
For me it is a great result
Oil burnt and sludge residue
A couple of hot spots on a couple of the plate rings
Most if not all friction plates have sufficient material left on them
Black oil residue coming out of TC
NO SWARF OR DEBRIS IN SUMP PAN
NO SPARKLY OIL
Conclusion
TC beginning to break up on its internal friction plates as suspected at 88,000 miles and no internal damage to gearbox internals whatsoever - valve block to be pressure tested, stripped and resealed
I reckon TC was within a couple of thousand mile from total failure and subsequent internal damage to gearbox
Plenty of pics taken and will be uploaded later
Current results are what I hoped for so am happy bunny !
Update later
Returned to VMTP tonight to deliver the Gen LR oil filter
Box now rebuilt
The valve block assy was stripped, inspected and re-sealed and as NO swarf had circulated through the system the bores were totally serviceable and no discernible wear was evident
BUT
an accumulator spring was found to be snapped (see pic below that was taken from another thread elsewhere and it lists the accumulator as being "overdrive clutch 4-5 shift"
All other pics are my own box stripped and then rebuilt
Had the call off Nigel at VMTP this afternoon
Car all done and ready to collect
They have road tested car and put it back on ramp to check for leaks and spanner check etc
I have asked them to keep overnight and do another road test from cold in the morning - they agreed no probs
Will update once I get it back and drive it for myself
Collected today
All good
Drive is very smooth
Overall am extremely pleased and regular (every 2 years) trans oil and filter changes from now on
Once back to unit tonight I flushed and replaced the anti-freeze
Now got all the other fluids to replace F/R diff, transfer box, engine oil and filter and brake fluid
UPDATE
Well just under a month has passed and a shade over 1000 miles covered since the new TC was fitted along with the gear box being stripped and rebuilt.
All is going great have towed with the vehicle and done a 400 round trip in 1 day so box has had a good work out.
Am returning to VMTP next week to have the ECU checked for pending or stored errors and the sump removed to check for "debris" and fresh transmission oil.
All the above (excluding oil as I supplied my own) is F.O.C. and part of VMTP's service and goes towards their 12 month parts and labour warranty (on any parts they fitted or labour carried out)
VMTP I used are in Cannock Staffs
At this time I rate VMTP as 11/10 !
They are ZF agents
My request was a new TC and strip/inspect/rebuild ONLY
It was found that an overdrive clutch plate was worn enough to replace and a spring was snapped in one of the accumulators on the valve block
Total bill was £1200 + vat (15hrs labour @ £50 pr hr)
Parts used were seals, O rings and gaskets, TC and overdrive plate
ECU read, cleared and software updated
1000 mile recheck etc as listed earlier
ALSO AT SAME TIME SUPPLIED BY ME
1 x genuine LR oil filter, sump seal and new bolts
1 x genuine LR trans oil cooler (old cooler retained by me)
1 x 20 ltr Texamatic 7045E correct spec trans oil (remaining oil retained by me)
1 x 5ltr correct spec A/Freeze (they topped up with water only on my request and I then drained/flushed/refilled once back at my own unit)
A.O.B.
I was clear on what I wanted and "assumed" nothing when negotiating what VMTP were offering me
Whilst there was no conflict at any time I felt VMTP "understood" exactly why I was having this done WITHOUT the gearbox being "broken first" and I was kept informed at all times.
Post #185744 30th Apr 2013 10:55am
You may want to look at the ecotune ecu for the gearbox so as to lockup the TC sooner and avoid less wear on it and the clutches within the box Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185753 30th Apr 2013 11:23am
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
There is a thread running on AULRO currently.
A trans workshop in Melbourne has started to experiment with better/stronger components within the areas that cause failures in this trans.
I dont have a Diesel I took the Petrol option on my L322, these failures were one of the major reasons why........
Not to be critical, but when I see shots of the underside of UK vehicles,,,,WOW they are in really poor condition, corrosion,oil leaks, dirt etc. There must be a lot of damage done to the underside of vehicles in winter with salt on the roads.
I guess our out back red/bull dust is not as damaging as one might think.
Post #216794 15th Oct 2013 11:35pm
SteveMFr
Site Sponsor
The 5L40 is not that bad. You have to know its shortcomings. That said, as I want to keep my TD6, building a tougher box is on my long list as well.
RS, sounds like you've done nearly everything to stave off a failure in the short term. It is a bit late now but one thing I would have done is a valve body upgrade. This is from another thread I posted to a while back:
I did considerable research on this transmission and spoke to all sorts of people from Ian Ashcroft, to John Mackey, to some very competent folks at Sonnax Transmissions.
The 5l40E has some very real problems - nearly all of which are pressure related. In a nutshell, the biggest wear issues stem from wear in the valve body bores and in the torque converter clutch valve bore. It seems that, for whatever reason, the aluminum used by GM in the casting of these pieces is softer than the material used in other (older) GM transmissions. This wear leads to improper shift/lock-up pressures which in turn leads to premature wear in the rest of the transmission components (which drop particulates into the fluid and exacerbate the wear in the valve bores) and, at some point, transmission failure.
All of the people I spoke to concurred on a number of items:
-'sealed for life' is not a good thing.As the filter is on the suction side of the system, it can't be made too fine as otherwise it would cause cavitation in the pump. These means that wear causing particulates, once in the transmission fluid, are there to cause damage till removed - or transmission failure. Early, regular fluid changes are good and necessary.
- using the proper transmission fluid is vital. The valves tend to oscillate relatively rapidly in their bores and the GM engineers put considerable effort into the interaction of the materials vs. pressures vs. wear problems. Use only the recommended fluid - not all fluid is alike.
- when transmissions are rebuilt, cleanliness is vital as is checking the tolerances in the valves and the pump
- after a rebuild, changing the fluid is almost more necessary than before to reduce the likelihood of a repeat failure
There used to be a more complete article on pressure loss in the 5L40 due to valve body wear on the Sonnax website but it has since been removed. Nevertheless these articles are good for info as well.
http://www.sonnax.com/publications/transmi...rse-or-tcc
http://www.sonnax.com/system/pdfs/177/orig...09-RCW.pdf
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #216877 16th Oct 2013 2:29pm
