Home > Maintenance & Mods (L322) > Keyfob Battery
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
Keyfob Battery
quick question
my key has stopped doing the remote lock/unlock thingy, manually locking/unlocking and starting the car is fine.
Could it be the fob battery and if so what would be the battery replacement number, mines a 2005 non flip type
CHeers
Post #21675 6th Jul 2010 3:52pm
jope
Norway 2003 Range Rover HSE Td6 Java Black
Re: Keyfob Battery
Polux wrote:
quick question
CHeers
if you have the same key as I have on my 2003 the battery is a standard cr2016 battery
Post #21676 6th Jul 2010 3:56pm
Polux
hi thx or that,
so while i go get a battery i istarted to use the spare key and everything seems ok yet the display on the dash i cannot change via the wheel ie time/mpg/radio stn is this an option somewhere ???
cheers
Post #21705 7th Jul 2010 8:26am
I'm not sure how it works on the older cars but in the newer ones each key has its own settings. try pressing and holding the indicator stalk button until either the centre screen or the dash gives you options or, go via the screen controls. You should find a page where you select which of the readouts you want to display. Discovery 4 HSE
Post #21709 7th Jul 2010 8:31am
Polux
wohoooo it worked, i luv you, will you marry me, I want to have your babies,, Very Happy
Post #21714 7th Jul 2010 10:10am
Steady on..... Embarassed Discovery 4 HSE
Post #21721 7th Jul 2010 11:33am
