Home > In Car Electronics (L322) > Tough screen sat nav camera updates
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi can I get a disc to work that gives the camera speed locations on that will just go in and play on my system.
Also I can have my tom tom in the van so its pointing the way you are going can this be done in the range roved so its not like you look as if you are driving sideways and backwards at times.
Its in a 54 reg Td6 Vogue
Post #216225 13th Oct 2013 9:46am
no speed camera poi's available on the fullfat touch screen version..
you can change the orientation in the menu so the travelling 'arrow' is always up.
i think you select 3d view in the user settings.. ... - .- -.
Post #216230 13th Oct 2013 10:00am
steve9bug
will give it a go thanks
Post #216233 13th Oct 2013 10:08am
As above Thumbs Up
Post #216245 13th Oct 2013 10:29am
Touch the little compass icon on the nav screen when its directing you. Will orientate the map either north at top or direction of travel. Works for birds eye view map, or use 3d as stan says. There is nothing that can't be fixed with a hammer😜😜
Post #216302 13th Oct 2013 5:10pm
