Home > Technical (L322) > Message: "CHECK SIDELIGHT" ?
Comes up on start up, turn on sidelights, get out and check, all working.
I have LED sidelights up front, been there for years, never given a problem before.
On ignition off get "FRONT SIDELIGHT"
Has one or both of my LEDs had its day ? .
Post #213241 30th Sep 2013 6:28pm
Joe its the "Bling" warning mate.... Wink
Post #213243 30th Sep 2013 6:30pm
those errors normally come up when theres a faulty bulb or a non-canbus bulb fitted..i suspect that one or both bulbs have burnt out their canbus circuit....or the bulb just needs re-seating. ... - .- -.
Post #213253 30th Sep 2013 7:35pm
+1 for ^
Post #213271 30th Sep 2013 8:37pm
Thanks guys, I'll have a play tomorrow .
Post #213286 30th Sep 2013 9:02pm
Had a chance to have a look. It was both LEDs, whether they have both gone at once, or it took both to trigger the fault, but see from the picture where the problem was:
Useful to know that even though this had happened they still worked as lights, even though they were throwing an error.
Anyhow, in the market for some new ones, what is the preferred LED sidelight these days? Did a search, bought some of these: http://www.ebay.co.uk/itm/2-x-NO-ERROR-FRE...219579323? .
Post #214390 5th Oct 2013 10:14am
Cheap Chinese crap! Let this be a lesson to you all as to how they can melt when they use sub standard electronics... Sorry Joe90 to cut accross your thread but have seen a few interior bulbs do this lately and would hate for one of our members FF's to go up in flames!
Post #214393 5th Oct 2013 10:24am
i've brought a fair amount of leds/smds and nearly all get dry joints within months of use, but a quick dabble with a soldering iron and they work ok again... ... - .- -.
Post #214398 5th Oct 2013 10:28am
Stan recommended them (the ones in the photo) Twisted Evil
and DMRR the ones I just bought. What is your preferred solution, Craig ? .
Post #214410 5th Oct 2013 11:04am
i did Confused
i do like these
http://www.ebay.co.uk/itm/2X-T10-501-W5W-C...27d8eab840
Post #214416 5th Oct 2013 11:23am
The bulbs I used are very bright, almost brighter than the H7s in my foglight DRLs, don't give a canbus message, but blink every 20 seconds or so (this must be the canbus test) .
Post #216077 12th Oct 2013 3:39pm
you can switch off the hot monitoring with an IIDTool, but you probably knew that already.. ... - .- -.
Post #216078 12th Oct 2013 3:44pm
Always too embarrassed to ask what hot and cold monitoring is Embarassed .
Post #216080 12th Oct 2013 3:46pm
thats when the ecu checks to see if the bulb is ok..cold on start up and hot whilst engine running..
so if you have non-canbus bulbs it'll throw up an error. ... - .- -.
Post #216082 12th Oct 2013 3:54pm
