![]() | Home > Maintenance & Mods (L322) > remove tv tuner |
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
The TV tuner is screwed onto the backing plate from the other side, so you needs to take the tuner & backplate out then separate them. I used two pieces of light angled aluminium 25x25 mm to make new mounting bracket for the new tuner & drilled them to match the original mounting holes on the steel back plate. It was a straightforward job and only took about 30mins to mount the new tuner onto the original back plate.
kruger2002 Member Since: 19 Jul 2013 Location: Newbury Posts: 70 ![]() ![]() ![]() |
Thanks for the swift response B9er. How does the backplate come off?
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I just fixed my new one against the original using velcro, then swapped the leads over. |
Pretty much the whole setup has to come out to release the back plate. Some people just wedge the new tuner down the side of the old one and make do with that. I preferred to make sure it was well secured and didn't see any point in lugging around the old tuner. It's not difficult to dismantle and reassemble the electronic grub bins and their mounts. The whole thing start to Finnish took me just over three hours. Should've been old enough to know better...doh!
I've got the RSE fitted so looks like the whole lot is coming out.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
When you plug the analogue tuner back in does everything work as it should? Previously..
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Is this what I need to sort my tv out its still on analogue and I want it working again what do they cost |
It's what I ended up doing.
I don't have rear screens but I am on a touch screen sat nav |
The hybrid tuner works well, RSE or not. If you have access to some form of coding, IID, Test Book etc, programme the vehicle with the hybrid TV option. It will still work if you don't, but won't list a TV tuner error code if you do |
Ok so after missing out a step |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 555 ![]() ![]() |
Kruger. Pop round tomorrow if you like. We'll tackle it together if it helps |
