Home > Maintenance & Mods (L322) > Dull thud, ?
onyx
England 2005 Range Rover Vogue Td6 Java Black
Dull thud, ?
Hi,last couple of weeks annoying ' dull thud' coming from top of engine bay ?.Cant feel anything thro the steering and JUST past the MOT this week.Seems to be coming from more over the passenger side.Any thought,ways I can find it without buying anything first.
Cheers Mark
Post #215746 10th Oct 2013 9:12pm
Ragerover
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Zambezi Silver
Next doors cat ? Growing old is compulsory Growing up is optional
Post #215748 10th Oct 2013 9:24pm
a dull thud description is pretty vague...we're good here but not that good... ... - .- -.
Post #215802 11th Oct 2013 8:12am
onyx
Just tried raising n lowering the suspension and it goes up and down as requested but the near side does make a 'creaking' sound. Is this a warning of bag failure or is there a joint that needs attention ?
Post #215842 11th Oct 2013 12:26pm
stick in off road, liberally spray some highly concentrated fairy liquid/water onto the whole strut ..look for leaks , if none the 'lubrication' might just stop the rubber sticking.. ... - .- -.
Post #215844 11th Oct 2013 12:31pm
And stan's and expert on Rubber and Lubrication ..... Laughing Laughing Laughing Wink
Couldn't resist Stan .... Laughing Thumbs Up ====================================
Post #215849 11th Oct 2013 12:51pm
Laughing
i just knew it would be you .. Laughing ... - .- -.
Post #215850 11th Oct 2013 12:55pm
onyx
Update ,couldn't see anything wrong with joints etc. so bit the bullet and ordered a new Delphi n/s strut unit.Decided to go with these as read differing views on here regarding Dunlops.Anyhow, removed the unit in 1hour and to my surprise see that it is a Dunlop with a date sticker on 10/10 ?.Checked it out and bag looks fine but seems a bit of play at the top.Is there a rubber seal under the top plate that can be changed ?.Checked out the o/s unit and this is a Delphi ?.Is this the original that has outlasted a 3 year old Dunlop unit ?.Will be ordering a unit for this side now as the 'dull thud ' has gone and it rides on AIR again.Looks to me as someone has changed one side and not the other but it is still going strong !!
Post #217505 19th Oct 2013 11:37am
onyx
Post #217530 19th Oct 2013 12:49pm
onyx
Post #217533 19th Oct 2013 12:50pm
The sealing ring (metal looking one) at the top looks a bit lopsided to me, could be the cause....
There is no rubber seal, but there should have been a thin papery gasket between the top of the strut and the turret - it is usually stuck to one or the other... .
Post #217536 19th Oct 2013 12:52pm
onyx
If you hold a top turret pin with each hand you can wiggle it, it seems quite loose ?.No gasket on either part.
Post #217552 19th Oct 2013 2:16pm
There is a bearing race in there, this could be shot? Gasket probably discarded when the Dunlop was fitted .
Post #217614 19th Oct 2013 8:35pm
onyx
Feeling the top I would agree with the bearing being shot and giving the Dull thud.Will change the other one this week now.
Post #217683 20th Oct 2013 11:03am
onyx
Changed the o/s strut today, only horror was the bottom pin.1 hour of banging/ turning notch by notch until it freed up.This one still had the paper gasket ( original Delphi ? ).Are these any good to anyone ?, neither of them leaked, just the dull thud from the n/s top bearing joint.Will be dumping them next week.
Post #218506 24th Oct 2013 3:58pm
