Home > Maintenance & Mods (L322) > leakage
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
leakage
Hi
I were under the RR today changing the engine oil. That was when I noticed this leakage:
Its from the left front side (driver side, Not uk driver side). I realy dont know the right terms do describe this leakage, sow plz help me out. -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #214980 7th Oct 2013 5:18pm
Big Boy R44ROV
Can we have a bit more detail....Engine type? Petrol/Diesel/TD6/TDV8/V8 age, model, mileage.
Post #215011 7th Oct 2013 7:02pm
Is this on the left side of the vehicle? (looking from the driver seat)
Looks like it could be diesel from the array of pipework around the fuel filter/oil filter or fuel pump in that area
Post #215020 7th Oct 2013 7:42pm
Norway
03 td6, left side when sitting in the car.
I can take some other pictures in the morning. -03V td6
Post #215051 7th Oct 2013 9:02pm
If it isn't dripping on the ground it could be oil from previous filter changes. Some mechanics can be rather messy
Post #215064 7th Oct 2013 9:19pm
Norway
Oh, but its dripping. -03V td6
Post #215065 7th Oct 2013 9:26pm
Norway
 -03V td6
Post #215366 9th Oct 2013 8:01am
You need to clean all the area and the above area and monitor it to see where the leak is coming from. I can't tell from the pictures if it's diesel or oil, maybe you could confirm
Post #215382 9th Oct 2013 9:17am
pld118
Hi. I had some leaks. Not a clue if they're similar to yours but the attached thread will let you make your own mind up if you've not seen it before.
http://www.fullfatrr.com/forum/topic20141.html?highlight=leaking
Good luck whatever it is Thumbs Up
Post #215408 9th Oct 2013 11:19am
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
Could be power steering fluid,have you checked it lately???.the resovour is on that side on a td6.
Post #215566 9th Oct 2013 9:36pm
