Home > Technical (L322) > HTC Fault suspension lowering |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Thanks to this forum I was able to prevent myself messing my pants when this error message appeared yesterday. I had been working on realigning my rear light and as a result the rear boot lights had been on for prolonged period. After I jumped into the car started fine but then was listening to the radio with engine off for about 15 mins. Turned ignition and got the dreaded HTC fault.I had the iid tool and was able to check battery level it was at 11 volts meaning suspect battery .left it over night on charge went out this morning and all well. Battery has been dodgy for a while its a bosch and only 2 years old so hopefully should be able to get a replacement through 5 yr warranty as its only 2 yrs old. Present :2008 TDV8 HSE
6th Oct 2013 1:15pm |
Managed to get a replacement battery under warranty just in time for winter too happy days Present :2008 TDV8 HSE
6th Oct 2013 5:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35161 |
i did the same as you Conner... my year old 020 started to suffer a bit , probably cos i didnt use the range enough and ECP changed it without any quibbles.. ... - .- -.
6th Oct 2013 5:37pm |
