Home > Maintenance & Mods (L322) > TD6 '02 FFRR Rear Subframe Bushes Replacement |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Been getting an MOT advisory on these for two years now, had the new bushes for at least a year, but not had the right kit or the inclination to complete this job. Pleased to say now well on the way. If you read my rear suspension howto you will have seen I had hoped to swap out the subframe bushes then, but my made up kit was not man enough for the job. Purchased a 12cm square of 1/2" iron with a 20mm hole in the middle. I was now able to use this and my bush press kit to have another go.
1st Oct 2013 6:22pm |
Putting back in should be easier until the last third when things tighten up a bit, and with rubber coated bushes the resistance is not so restrictive.
2nd Oct 2013 12:53pm |
More on the OSR-RR
2nd Oct 2013 12:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35273 |
wiki'fied Tim.. ... - .- -.
2nd Oct 2013 1:15pm |
2nd Oct 2013 5:58pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
Is this TD6 specific or applicable to all L322? Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
12th Aug 2016 12:53pm |
Pretty certain it covers all L322s of that era at least. You could check with Dan at Duckworths who could confirm if bushes are different for anything other than an '02 onwards. .
12th Aug 2016 3:41pm |
I wasn't sure, Joe, because it's in the TD6 wiki - an area I don't tend to read because I don't have a TD6. Ron B. VK2OTC
13th Aug 2016 4:40am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
The rear subframes are common across the L322's (at least up to facelift) and the BMW E53 X5 of the same era. You might find BMW bushes are possibly cheaper or more readily available. I picked up some new LR bushes cheap but used a BMW tool to swap them. |
13th Aug 2016 7:07am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Top Job, i feel another project coming on !! |
25th Oct 2017 6:30pm |
Bolert Member Since: 29 Jun 2021 Location: Hythe, Kent Posts: 30 |
Hi All,
6th Dec 2022 3:53pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 171 |
Just done the rear subframe bushes on the old beast, been mentioned on my MOT for a couple of years.
12th Dec 2022 4:25pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 397 |
Did mine this weekend, not super hard. 3 out of 5 spanner’s!
18th Jun 2023 5:42pm |
Cymraeg Member Since: 23 Feb 2023 Location: Cambs Posts: 2 |
Cheers for the posts guys. Attempting this week after next on my tdv8. Couldn't get bushes from LR so ordered some from craddock and have an x5 tool on the way. Anything else I should be wary of? |
28th Aug 2023 2:38pm |
