Home > LPG > Emer LPG system lazy starter
samp5679
I have a Emer LPG system and sometimes takes around 5 secs to start but only sometimes ?? this was also the case on the last range rover v8 on the BRC System anyone else have this problem
simon
Post #212759 27th Sep 2013 6:32pm
Trist78
2004 Range Rover Vogue 4.4 V8 Java Black
Do you not start on petrol and switch over automatically
Post #212780 27th Sep 2013 8:47pm
ebajema
Most if not all LPG systems do a petrol start and then switch to LPG quickly after that. If yours is a petrol starter, you may have an issue with the non return valve of the petrol pump starting to leak so the petrol drains back to the tank.
If that's the case there could be two things going on, wear of the seal or dirt caught in the seal area.
Other option is injectors that start to leak a bit and the petrol disappears that way.
If it is dirt in the fuel system, running it on "clean" petrol like V-Power and the likes could help. Run it on petrol for a 100 miles or so. Also maybe chuck some fuel system/injector cleaner in the petrol tank and do a 100 mls run with it. That would hopefully flush the petrol system clean. MY 2010 5.0 SC Galway green and sand interior!!
Post #212839 28th Sep 2013 9:59am
samp5679
thanks guys I will try that v max petrol and injector cleaner
Simon
Post #212878 28th Sep 2013 12:44pm
