![]() | Home > Technical (L322) > Speedo not working, no ABS, DSC.... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Just collected the car (will try and forget the �602.20 bill) complete new driveshaft and ABS sensor on the rear near side fitted.
Who is the Warranty Company? |
auto prtect.
I would push that claim as far as you can go if the only solution was replacement of the Driveshaft. |
To help others who may have this issue, the abs reluctor ring, as its known, that you can't buy separate to the driveshaft, is available here, separately ;
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Could be the reluctor ring from BMW E36 rear, because of 48 holes and 93,9 mm ???
That looks good.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
Another supplier for ABS Reluctor rings ( they have both rear and fronts, but I can't see any difference)
