Home > Technical (L322) > IID TOOL & Clearing 'Inspection' Message |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Which iid tool did you use? |
19th Sep 2013 4:28pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Standard one back when I first did it then I used the IIDTool BT few days ago. |
19th Sep 2013 4:59pm |
Bump |
5th Oct 2013 9:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35161 |
only guessing but have you thought of a battery dis-connection ? ... - .- -.
5th Oct 2013 9:48am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6709 |
If its anything like BMW, i reckon that The inspection date is written into a non-volatile area of (possibly) several ECUs in the same way that the mileage is, so that disconnecting the battery won't have any effect. Got - 2017 SDV8 Autobiography in Loire Blue
5th Oct 2013 9:52am |
I will give it a go anyway .... Its no major problem, just slightly annoying |
5th Oct 2013 1:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Try the manual approach in the wiki (secret codes) .
5th Oct 2013 3:03pm |
yrea tried that - didn't work |
5th Oct 2013 10:27pm |
try changing the date on the touchscreen to something after 10/14 then reset it again, then change the date back to normal..
6th Oct 2013 10:14am |
Yea tried changing the date but went backwards, the inspection message then showed 10/13. |
6th Oct 2013 11:16am |
