Home > Maintenance & Mods (L322) > Starter switch
Shaun6
Starter switch
Managed to push my finger through the keyless on/off rubbery button/switch, is this an easy fix and does anyone have the part number?
Thanks
Shaun
2011 VSE
Post #209843 12th Sep 2013 3:04pm
wealy
THE PART NUMBER IS LR011897 - They are about 25 quid from Dan.
Easy to replace I did mine a few weeks ago.
Post #210192 14th Sep 2013 9:34am
Shaun6
I have ordered one from Dan, assume you just lever out the silver surround and it all comes out and then slot the new one back in?
Thanks
Shaun
Post #210195 14th Sep 2013 9:41am
wealy
Yes - its as simple as that. I used a plastic spatular from the kitchen and it popped out. There are thre plastic prongs - when you get the new one it is self explanatory.
My previous owner was a lady and I'm guessing whe had long sharp finger nails that poked a hole in the centre if the button.
Post #210198 14th Sep 2013 9:46am
Shaun6
Mine was my own fat fingers!!!!!!!!!!!!
Post #210203 14th Sep 2013 10:09am
Shaun6
Wealt, how did you get yours out,I am having real trouble?
Post #210816 18th Sep 2013 7:19am
wealy
It simply pops out.
I used the new one as a guide and you will see the 3 prongs equi-spaced push the spatula or a thin screwdriver down the padding and it will pop out!
You need to be a bit confident when you pull it!
Very Happy
Post #210870 18th Sep 2013 9:09am
Shaun6
must be me, can get the top to come out a little, but not the bottom, I may have to save it for my next service and get LR to fit it.
Post #210879 18th Sep 2013 9:40am
wealy
If you weere a bit closer to me I would show you!
Trust me it will come out - you just have to be confident and give it a firm pull. If you break the prongs on the old one it does not matter as you are replacing the whole surround anyway.
Surprised
Post #210880 18th Sep 2013 9:46am
Shaun6
Sucess, I used the spatula to ease it out a little, then some BBQ tongs to get it a serious tug.
Thanks for your help.
Shaun
Post #210886 18th Sep 2013 10:07am
