Home > Maintenance & Mods (L322) > Front fog lamp bulb replacement
J90
France 2006 Range Rover Vogue Td6 Java Black
I have used the search function but the amount of info is overwhelming so I want to ask 2 simple questions -
Are the front fog lamps on a TD6 facelift H11 fitting?
Can you use a xenon type replacement in the fog lamp housing which I believe has a plastic lens.
I realise that a more yellow light cuts through fog but I'm after a whiter light.
Ta ..
Post #210482 15th Sep 2013 7:26pm
Delete
Post #210484 15th Sep 2013 7:31pm
Prop
From recollection the 2006 does use H11 fitting 55 watt bulb for the fog lights. Not sure about the xenon types you could use though.
Post #210494 15th Sep 2013 7:45pm
J90
Thanks Prop. 1 question answered, 1 to go Smile
Ta
Post #210496 15th Sep 2013 7:47pm
get white halogen h11 bulbs from ebay..cost about £6 for the pair..
or go led/smd...be careful on the size of the bulb as the light hole is small and the larger smd bulbs dont fit.. ... - .- -.
Post #210503 15th Sep 2013 8:30pm
