Home > In Car Electronics (L322) > iid tool Tight tolerance ?
Googsy
Is the IID tool able to put the suspension into tight tolerance mode as recommended by Landrover for optimum alignment? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #210259 14th Sep 2013 5:24pm
what does that do Conner? ... - .- -.
Post #210285 14th Sep 2013 7:47pm
Googsy
Apparently it sets the suspension setting to the optimal position so that alignment can be done accurately. It is recommended this is done before having a 4 wheel alignment done.
see here borrowed from our sister site worrying thing is every alignment i have had has been done at std ride height as I'm sure most of us have.
http://www.rrsport.co.uk/forum/post391319.html Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #210287 14th Sep 2013 8:01pm
interesting, thanks. ... - .- -.
Post #210290 14th Sep 2013 8:11pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
hum i wonder if there's a tool to set the wife in an optimal position so that alignment can be done accurately.
I don't mind the std ride height but tighter tolerences sound better.... Laughing Laughing
ps delete if inappropriate
Post #210293 14th Sep 2013 8:22pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
Set tight / normal tolerance
This will set the EAS ECU into tight or normal tolerance mode. In normal tolerance mode, the EAS ECU
will adjust a corner when it’s +/- 10 mm or higher than the desired height. For example if the corner is
at +9 mm, it will not correct the height. If the corner is at +11 mm, the EAS ECU will make adjustments.
In tight tolerance mode, a tolerance of +/- 3 mm is used.
CAUTION
The tight tolerance mode should only be used when calibrating or
when the wheels are aligned. Leaving the EAS ECU permanently in
this mode can lead to premature failing of components
a quick chop from the instructions says it can
Post #210317 14th Sep 2013 9:30pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Rolling with laughter
 Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #210445 15th Sep 2013 4:01pm
SteveMFr
Site Sponsor
Thanks, Soggy.
If Dan were still around there'd be a "RTFM" coming... Laughing
Please do not leave the vehicle in tight tolerance mode, though. It will cause issues. Some of us here know this little detail more intimately than most others. Whistle
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #210539 16th Sep 2013 10:24am
