![]() | Home > Technical (L322) > Suspension Fault Max Speed 30mph |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
sounds like you have a split/hole in one or more airbags and the compressor is working overtime to keep it inflated..
PaddyR Member Since: 30 Oct 2012 Location: Dublin Posts: 5 ![]() ![]() ![]() |
I have put it in off road mode and lifted each corner but can't hear any hissing. The garage say they did the fairy liquid check but I'll do it again myself at the weekend to double check. Thanks for the advice. |
Are the height sensors all ok ? Present :2008 TDV8 HSE
Check the hoses as well, they sometimes split or the connectors break/come of etc.
I will check the hoses and connectors thanks.
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
I had a disco that randomly kept going down, eventually traced the problem with a scope by checking the wiring from the ride height sensors to the main engine loom plug. The signal wire to the sensors should be at 5v. When operating the sensors by hand with a scope or good meter you should not see any drop out (i.e. disconnecting them & operating them by hand). A continuity check will show a broken wire however in my case it was being caused by corrosion in the wiring, in this case the high resistance through the corroded wiring caused an occasional spike which dropped the signal on its way back to the ECU.
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
the wiring loom of front sensors are genuinely cable tied to frame an Td6
Level sensors are only about £25-£30 each, worth changing all 4 at the same time then have a re-calibration done as this is essential after changing sensors.
I agree with the others, having a good look at all the height sensor related issues is a good way to go. And replacing some or all of them is probably a good thing as well. Considering the age of the car and the environment the sensors are living in, you could expect this by now. MY 2010 5.0 SC Galway green and sand interior!!
No I have never get the HDS INACTIVE message. When I get the Suspension Fault - Max Speed 30mph" message all the orange lights extinguish on the height adjustment lever and the suspension deflates. Also, one other thing - since this problem started the height lock button has not worked. Just wondering would this be related to my problem and does anyone know what the fix for it is? |
wilko13 Member Since: 13 Mar 2015 Location: Berkshire Posts: 1 ![]() ![]() |
Hi I no this post was a while ago but I've this problem now and wondered if you ever got to the bottom of it? |
I did get it fixed eventually thank you.
Needmorepower Member Since: 03 Mar 2017 Location: Armagh Posts: 6 ![]() ![]() ![]() |
Hi Paddy my 06 doing same on long journey and suspension a tad stiff.
RJ333 Member Since: 28 Jun 2020 Location: Florida Posts: 3 ![]() ![]() ![]() |
I had faults similar to the OP. I cleaned out my compressor exhaust filter (sintered bronze filter) with air, then acid, then gasoline (over three different episodes). And each one helped. But I then changed the dyer dessicant in the compressor assembly and I haven't had the problem yet after my 2 hour trip. I hope that solved it.
