![]() | Home > Maintenance & Mods (L322) > DRL's again ... |
Technically I don't see any reason why not. You can just do it the old fashioned way, direct connection to a fuse with sufficient capacity of a spare fuse, switch to LED DRLs. Or direct from the plus pole, fused wire and then the rest.
No reason at all you couldn't do what you want.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
the hardest bit is to find a route for the cable from the interior to the lights outside.. ... - .- -.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Have you upgraded your sidelights to LED's yet? That really makes a big difference, even in the daytime they are nice and white. Previously..
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Quick replies as usual!
What about....... Linking the DRL's so they switch on with the sidelights but switch off when main lights are switched on?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
Do you really want switchable DRL's or are you just looking for something to switch so that you can fill the empty space ?
Your DRL's have to dip/dim when the headlights come on. MOT man might not like them being user switchable, although this would be no different to "driving lamps" I guess.
Joe90 Technically, You cannot use the foglamps as DRL's
Craig, its not a legal requirement to have front fogs so converting them to drl's is ok.. obviously you have to remove the high power 55 watt halogen bulbs and replace with low power smd/led's.
You can get the LED rings for the foglamps and use the rings as DRL's while retaining the foglamp functionality. There is a thread here on the forum about how to.
like these Eugene,
I tend to agree with Craig on this, if you simply remove the existing fog lamp bulbs and replace with leds the lamp fitting is still a foglamp as prescribed by the car manufacturer. You cannot imo simply call it a DRL.
Exactly my point sir... Stan, you can remove the lamps and replace them with a DRL lamp |
