Home > Technical (L322) > transmission fault only limited gears available
dingg1
right now - only had the RR back on the road for a week or so and keep getting the message in title
car gives me 3 gears and reverse but if I shut her down for a minute after driving a few hundred yards everything is back to normal , I know it won't fix itself but do I need to get myself lubed up for a right royal rogering or is it a common 'they all do that sir' and just ignore until it no longer sorts itself out as it seems to be doing now?
over to you guys with the knowledge
Post #209284 10th Sep 2013 11:02am
Could be a transmission overheat. Have you checked the Transmission Oil Cooler as this may be blocked especially if the radiator is sludged up. You may want to take the external Gearbox temperature next time.
Post #209285 10th Sep 2013 11:07am
dingg1
it only happens first time I start her up - cold engine after standing for a few hours
, new cooler fitted too along with rad pack
thanks though for the quick thoughts on it
Post #209286 10th Sep 2013 11:16am
ebajema
Can you please update your car icon so we know which box it is ? It may help finding the cause. MY 2010 5.0 SC Galway green and sand interior!!
Post #209295 10th Sep 2013 11:56am
dingg1
anyone??
Post #209493 11th Sep 2013 10:26am
not every knowledgeable member is on the forum every day , some only come on at the weekends or evenings ...
i'd have patience .. ... - .- -.
Post #209501 11th Sep 2013 11:03am
dingg1
Cheers Stan - it is one of my faults - Cool
hasn't done if for a while - may have magically fixed itself Neutral
Post #209519 11th Sep 2013 11:37am
RRPhil
To be honest, compared with the 5-speed ZF & GM units, there haven’t been a lot of issues reported with the 6-speed transmissions so there isn’t a lot of experience to tap into at the moment. I guess there’s a couple of reasons for this :
1) the transmission is obviously newer, so Range Rovers fitted with the 6HP26/28 are all under 8 years old with corresponding 'low-ish' mileages
2) the transmission appears to be generally very robust (if you ignore the 2-1 rollout shift issues and the selector lever linkage seizures)
The same driveline arrangements (engine + transmission + transfer box) are also used in Discovery 3 & 4 and the Range Rover Sport so there may be similar issues reported on their forums? The 6HP26 has, of course, been around since 2001 in other vehicles so there may possibly be others with similar experience on the BMW & Jaguar forums.
All I can suggest right now is that you get the codes read to see if that gives any further clues.
Phil
Post #209538 11th Sep 2013 12:54pm
dingg1
Cheers Phil
hoping its just a sensor issue as the car hasn't been used for a 3 months or so
Post #209539 11th Sep 2013 1:04pm
ebajema
I don't want to discourage you but have a look at my posts regarding this gearbox. RRPhil has been great helping me to find the solution (waiting for a full set of coils now).
Like Phil said, first get the codes read.
Can you notice anything unusual in the gear change behaviour of the gearbox ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #209564 11th Sep 2013 2:59pm
dingg1
hi Ebajema
I'll have a trawl through your posts , but to answer you the box is changing up/down perfectly , it has only gave me the 'limited gears' on 4 or 5 occasions , and appears to have fixed itself Surprised
I've had it in to a local place to recharge the aircon but they haven't been able to get the system running properly , i intend to take it to someone who knows what they're doing soonish to get it sorted , and will have the g/box fault codes read then
Post #209570 11th Sep 2013 3:42pm
ebajema
Good to hear the gear changes are fine. It could be something related to sitting still. One thing that is an issue sometimes is the gear linkage. If you get a chance, liberally spray the linkage underneath the car with WD40 and then cover it in simple white grease or something like Shell Rhodina II (specially developed for open gears offshore, so really good in place like the UK, NL etc.) MY 2010 5.0 SC Galway green and sand interior!!
Post #209571 11th Sep 2013 3:45pm
RRPhil
Hopefully it will turn out to be caused just by low battery voltage, if the car hasn't been used for a while.
Phil
Post #209645 11th Sep 2013 11:44pm
dingg1
Found out what the issue was
quite simple really and I can replicate the problem easily.
If I quickly start the car without a second or 2 pause to allow all the ecu's to communicate I get the fault pinged up. So it turned out to be just a quirk with my starting technique , could someone test it out for me and see if it happens with there car??
straight from off to start without a pause caused the error in mine
codes all read and cleared and were comms errors
Post #217856 21st Oct 2013 11:55am
ebajema
Glad it was a simple fix Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #217870 21st Oct 2013 1:29pm
