Home > Technical (L322) > Odd behaviour from Deployable side steps
RXWRR
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Recently had a set of deployable side steps installed by the dealer, but of late I've been noticing what seems to be odd intermittent behaviour from them, examples of which I've listed below:
Unlock RR, steps deploy as normal and retract if door is not opened after a minute. Opened boot to get something out, closed it and both steps deployed Shocked Similarly, opened drivers door to release bonnet latch, steps deployed as normal upon opening door, closed door and steps retract as normal. Finished under the bonnet and closed same (with a slight slam, as you do!) and both steps decide to deploy...!  Shocked
Yet another example... Leave steps to retract without activity, lock RR and steps suddenly deploy briefly and then retract, almost as though they are confused, its quite bugging!... I assume this isn't normal?
Called the dealer, to report same and they didn't seem to have any ideas/answers and won't do anything unless they witness the odd behaviour for themselves, sods law though it won't occur when at the dealer.
So anyone with experience of this kind of thing happening, so I can arm myself before frequenting the dealer...?
Over to the experts Bow down
Thanks in advance...
Ray Better to be irresponsible and right, than to be responsible and wrong.
2010 Vogue 4.4 TDV8 Santorini Black, Jet/Ivory interior
Post #209132 9th Sep 2013 8:57pm
ebajema
Let them first check all the connections, wires and switches. Then make sure the latest software is installed and then use it again for a while.
It sounds like a loose connector or a small wiring problem or a connection issue. MY 2010 5.0 SC Galway green and sand interior!!
Post #209136 9th Sep 2013 9:00pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Mine do exactly the same. I wondered too but as it doesn't cause me a problem have decided to let them play. Laughing 4.4 TDV8 Vogue Baltic Blue MY11
Post #209141 9th Sep 2013 9:08pm
Mine too Whistle Only the lock thing though Thumbs Up
Post #209200 9th Sep 2013 11:21pm
Can you change a wheel when you have these deployable steps on ....
Post #209203 9th Sep 2013 11:23pm
Baron
Got to unscrew 4 allen screws to remove a step to provide access to the jacking point. A faff but no big deal. 4.4 TDV8 Vogue Baltic Blue MY11
Post #209205 9th Sep 2013 11:25pm
The book says for the step to be removed before jacking... Shocked
Post #209206 9th Sep 2013 11:26pm
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Mine do the same thing & have done for years so I just ignore them & let them get on with it. Wink
MD said not covered under warranty as dealer fit accessory & only cure would be replacement of complete system with no guarantee of better behaviour.
Mick you can change wheels with the steps on if you use a trolley jack - I would never use the jack supplied with or without steps Thumbs Up
Post #209211 9th Sep 2013 11:32pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I've jacked mine up with sidesteps using a bottle jack. I locked the steps in the deployed position (or just leave the door on the latch). The jack fits in the point fine. The only slight problem is you don't get a lot of space to pump the jack handle up and down. It does work however. Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #209291 10th Sep 2013 10:31am
RXWRR
Spoke with dealer today and suggested it may be a loose connection/wiring issue... Response was "it's a new one on them, never heard of this happening before" Rolling Eyes booked in tomorrow to take a closer look so fingers crossed.
It's by no means a major issue, I accept that, just somewhat irritating! Besides I paid enough for them, the least I could expect is for them, to work 100% as intended!
Will keep you posted on their findings... Better to be irresponsible and right, than to be responsible and wrong.
Post #209294 10th Sep 2013 10:49am
