Home > In Car Electronics (L322) > can anyone help installing car audio amp
Jackofq300
United Kingdom 2002 Range Rover HSE 4.4 V8 Zambezi Silver
does anyone know how to install an after market amp and subwoofer into a range rover hse. the car is a 2002 but it has the upgrade tv n satnav. i have been told you can install it all from the boot apart from the main live. can anyone help as i cant seem to find manual online. thanks
Post #208275 5th Sep 2013 1:29pm
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
It's a very complicated system and something I wouldn't do unless you have some serious car audio skills
The easiest way would be to get a high power speaker wire to low power RCA connector and run new separate power and ground cable! Remote would have to either be on a switch or relay or off the headunit. Depending on headunit?
This way isn't always that great but for sub it should be ok. The only other way is running a special box of tricks like an audiocontrol lc6 or a audison bit ten! (Complicated and expensive)
This is what I did with my system
http://www.fullfatrr.com/forum/topic17535....ftermarket
Post #208344 5th Sep 2013 6:00pm
^ That really was a cracking job. Thumbs Up Previously..
Post #208347 5th Sep 2013 6:08pm
SATVC
Thanks buddy, it's changed a lot since then.
New kenwood double din, reverse camera, different sub woofers etc
Lovely system IMO and very pleased!
Post #208348 5th Sep 2013 6:09pm
Jackofq300
ok thanks for your help mate. might go for the ch.eap solution
Post #208523 6th Sep 2013 3:48pm
Jackofq300
Post #208524 6th Sep 2013 3:49pm
