Home > Technical (L322) > Battery Charging Warning
markdotreed
Not sure if I've committed some sort of schoolboy error but went to retrieve my Vitesse this afternoon and it wouldn't start. Had some jump leads with me and boosted it off the SC. all went well but after disconnecting the leads and packing up a fault appeared. Battery Charging fault and the battery light has stayed on. Manual says 'seek qualified assistance urgently'
I'm a little surprised that this has happened... But have I cocked something up?? Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #208355 5th Sep 2013 8:21pm
first thing to do is to disconnect the battery, wait about an hour then reconnect...dont forget to turn the steering wheel fully left then right.
hopefully this will rest everything......... ... - .- -.
Post #208360 5th Sep 2013 8:36pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
With the engine running check your battery voltage, make sure it's around 13.5v to 14v.
The battery light will come on if the battery voltage (charging circuit) is less than it should be. You may have just drained an already low battery by jump starting another car, it might just need topping up. Worse case, the alternator is Censored .
Post #208724 7th Sep 2013 4:54pm
