Home > Maintenance & Mods (L322) > TDV8 3.6 FFRR Oil Change - How to |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Some additional information and images to add to andrewb's excellent tutorial on the oil change for a 3.6 TDV8
4th Aug 2018 8:37pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Today I did my first oil/filter change on the 3.6 tdv8. It’s normally done by my local Indy at least for last 4 years since I’ve owned it.
11th Nov 2018 11:53am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2383 |
I never get under a vehicle with air suspension without axle stands or at least first disabling the air suspension by removing the 20A air suspension fuse (L322 MY07+, all D3/D4/RRS). The 20A fuse supplies the power to operate the valves so with this removed, at least the suspension system can't decide to lower. |
11th Nov 2018 12:16pm |
Good point. Another reason for ramps so the car is at least 300mm off the deck. ______________________________
11th Nov 2018 1:05pm |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
Hi,I've changed the oil on my 3.6 Tdv8 several times and am always surprised how little oil ( half a coffee mugs worth) drops out....so why is this,is the oil in there in a different compartment to the main sump and what exactly is the point of that rearmost sump plug? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
11th Nov 2018 5:23pm |
The rear-most plug drains the small turbo return drain line reservoir.. If not drained then sludge will build-up eventually blocking the turbo drain return lines causing oil to backup to the turbos and escaping via the turbo seals. |
11th Nov 2018 8:42pm |
Ah thanks for the explanation.Ive never bothered with using flushing oil first,is there any merit in doing so? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
11th Nov 2018 10:34pm |
I personally think oil flush is worth the expense (small in comparison with turbo replacement and engine rebuild) and effort.
12th Nov 2018 12:39pm |
So what's the oil flushing procedure please?
12th Nov 2018 3:40pm |
I always drop the oil every 6000 MLS,an hour of a job costing around £60-70,like you say small price to pay v turbos etc etc. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
12th Nov 2018 3:42pm |
The procedure is to add the flush treatment to the engine oil when an oil change is due and run the motor on a fast idle (I kept it at about 1500 rpm) for 30 minutes. Then a normal oil and filter change (drain the oil, replace the oil filter, refill with new oil). ______________________________
12th Nov 2018 8:19pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Unnecessary quote removed
2nd Aug 2020 12:51pm |
I do not think so. You will have to wait until the next oil change. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
2nd Aug 2020 4:12pm |
Oops 2010 3.6tdv8 180k km.
2nd Aug 2020 4:30pm |
