Home > Maintenance & Mods (L322) > Engine oil flush |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
It’s a bit like using champagne as mouthwash before you brush your teeth, won’t do any harm just a bit excessive |
31st Aug 2013 9:25pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Cant see its a bad idea, though i would make sure that the "budget oil" is the the correct spec as you will no doubt, with the best will in the world not get all of it out.
31st Aug 2013 9:30pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
If it is of a compatible oil type then yes, why not. If it was the wrong stuff that would potentially leave a residue then no.. But you know what you are doing. I once nearly put an oil cleaner/flusher in my FFRR but thought it will more than likely leave some chemical behind that will damage the new oil, so I never did.
31st Aug 2013 9:35pm |
Best thing is to get the engine fully warmed through. This is normally achieved after about 20 mins of steady driving.
1st Sep 2013 7:30am |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Thanks for your thoughts folks. The oil is left over from an earlier project and I wanted to put it to good use. I'll double check the specs before I use it.
1st Sep 2013 8:31am |
Part of the joy of Petrols with honey coloured oil.... |
1st Sep 2013 8:38am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
That's not an engine flush, it's just a short oil change.
1st Sep 2013 6:12pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Why ATF ? keen to know . 2008 MY Supercharged
2nd Sep 2013 2:29am |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 |
^^^^...likewise, why use ATF ? free use of "RSW" all comms to anyone nearby |
2nd Sep 2013 3:34am |
It has a high detergent content and doesn't foam up. I was first told about it 25 years ago. And used it for more than 25 years on bikes and cars. The BMW K series motorbikes have a starter clutch that is prone to sticking if the oil isn't changed when scheduled, or if the bike has been stored. The starter clutch is inside the engine, and if it needs to be replaced is a huge job which requires all the transmission, clutch and bellhousing to be removed before you can get inside the rear of the engine, a £600-£700 job, plus parts. Adding ATF to the enginje oil and bumpstarting the bike and leaving it running for 20 minutes frees up the sticking starter clutch in 99% of cases. I have run my own bmw business for more than 25 years and have many a thankful customer due to ATF |
2nd Sep 2013 12:11pm |
