Home > Camping, Caravanning and Holidays > What mirrors do you use
n1cktdv8
I have Milenco grand aero's and they have a straight arm bar to mount. The FF has a curved mirror housing so before I stick them in a pipe bender has anyone else experienced this ?
What mirrors do you use ? Is this where I put the car details and a bit about myself ?........
Post #205799 26th Aug 2013 6:19pm
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Halfords do some about �8 each that have elastic hook type straps and Ive used them without issue. I prefer them as i don't like to 'screw clamp' them to the car mirrors. I found them in store as they're not on their web site 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #205801 26th Aug 2013 6:25pm
RCusden
Wales
I also use the aero's good mirrors just put up with the curve in the ffrr mirror and they seem to work well but I like the idea of using a pipe bender to get them to fit better Bow down
Cheers roger
Post #205831 26th Aug 2013 9:09pm
n1cktdv8
I have some same diamter stainless at work and am going to get them bent to same curve as mirror housing. Am not a fat of the rubber strap ones but am going to get the milencos to fit Is this where I put the car details and a bit about myself ?........
Post #205844 26th Aug 2013 10:36pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I don't use any Laughing Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #205942 27th Aug 2013 4:21pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
The Suck it and see Vacuum type about �20 a pair on the bay very good and they can be adjusted with the mirrors
Thumbs Up Thumbs Up
Ps i think you need them legally even in a FF! Mine was a blue one! Smile
Post #205944 27th Aug 2013 4:26pm
n1cktdv8
It's a legal requirement. Pipe bender done and mirrors will be fine. Is this where I put the car details and a bit about myself ?........
Post #205947 27th Aug 2013 4:30pm
Yes definite requirement even for a full fat.
I think mine are pyramid ones, the fit nicely to the mirror housing with both a screw clamp
And straps. V solid and stable not too much vibration. There is nothing that can't be fixed with a hammer😜😜
Post #206112 28th Aug 2013 12:58pm
Shocked Oops - didn't know that - I don't usually bother - I find them distracting - even thre Milenco Aeros still seemed to vibrate.
My Milencos are in the garage at home, so i'll be driving home without any, but feeling more guilty this time.....
Post #206113 28th Aug 2013 1:10pm
Seems to be a width thing with the mirrors rather than towing - so I might just be OK - I'm towing a Jeep on a trailer and that's no wider than the FFRR Thumbs Up
http://www.caravanwise.co.uk/caravan-tips/towing-mirrors.html
Post #206114 28th Aug 2013 1:12pm
n1cktdv8
the law says "clear vision down each side of the towed trailer/caravan" or words to that effect. My caravan is 2.3m and thats wider than the mirrors...I like them too as they give me an idea when a lorry is heading up the middle lane Is this where I put the car details and a bit about myself ?........
Post #206115 28th Aug 2013 1:14pm
the law is quite complex, it involves being able to see a certain distance behind the caravan in line with the side of the van:
There is a legal requirement for you to have mirrors that allow you to see clearly an area that is 4 metres wide from the side of your caravan at a distance 20 metres behind the driver. A caravan is significantly wider than a car even a large 4x4 and you simply can't comply with the law unless you fit towing mirrors.
Post #206236 28th Aug 2013 9:02pm
Andy
I bought a cheap pair from Aldi. They're basically held on with big elastic bands and you can't really see much with them. They make me road legal though so I'm happy.
Post #206477 29th Aug 2013 5:24pm
We have 2-camera rear view system on our Motorhome I wonder if they would work with a caravan. You get a clear picture as if looking out of the windscreen backwards!
Post #206494 29th Aug 2013 6:07pm
I suppose as long as you can see the area in the picture then it should comply.... There is nothing that can't be fixed with a hammer😜😜
Post #206512 29th Aug 2013 6:40pm
