![]() | Home > Technical (L322) > Replacing TD6 Intercooler |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
The intercooler on my 2002 TD6 has sprung a leak!
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198 ![]() ![]() |
Before you buy one, have a look at ours -
Excellent, thanks Steve - cheapest price I've seen - just working out how to remove the old one! Current: 2010 Range Rover L322
Only seen the D3 IC come off - Grille, Headlamps, Bumper then all fairly obvious Paul Redding
Enough of the front end to release two plastic clips (I've taken bumper off, but not really convinced I needed to, except to clean up some of the oil). Then IC comes out through the back, which means removing viscous fan to make enough space. Now to try to remove the viscous fan! Current: 2010 Range Rover L322
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Could you not ask the independent specialist to source the part from AF on your behalf rather than original LR part?
@steveball.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
All the info I can find is NAS, so doesn't have the Td6 in it.
Right, have fired up the steam powered old Rave, here you go:
Thanks so much Martin that's really fantastic. Any ideas where I can lay my hands on the version of RAVE that you have for future reference?
Thanks Martin that is exactly what I needed. |
If you want the Rave with TD6 info:
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
I've done it
