Home > In Car Electronics (L322) > in car camera dvr
in car camera dvr
so i sold my rather large in-car camera dvr and decided to get a smaller unit..i ordered and received this compact unit for £30 all in from a UK ebay seller...
its a 720p jobby which i intend to stick on the front screen behind the rear view mirror with the double sided tape provided...the single wire will be fed into the headlining and down the near side pillar, under the tread plate and then under the seat to the center console area...it has no view screen so i will wire to my RSE which will allow me to view the recordings and also let rear seat passengers have a live view of the road ahead...
i'll post some pics when its up and running ... ... - .- -.
Post #204091 15th Aug 2013 10:42am
That's how I wired mine Thumbs Up
Headlining was OK, but I couldn't get the wire down the side of the dash, so fed it through the glove box - details here and also cabled the video out to the RSE.
Post #204107 15th Aug 2013 11:19am
that indeed is a better cable route, thanks Alistair... Thumbs Up ... - .- -.
Post #204112 15th Aug 2013 11:39am
question for you Alistair, i gather your blackvue lens has movement up and down and not side to side, so because yours is on the left of the mirror does it view the path/pavement more than the incoming traffic on the other side of the road ... ... - .- -.
Post #204155 15th Aug 2013 3:11pm
It did, but only slightly - I've since moved it so will have a go with the iPhone upload Cool
Post #204165 15th Aug 2013 4:49pm
Can't get the upload working Big Cry
The camera is now a bit lower and central - it is more obvious from outside, but completely behind the mirror from the inside.
Post #204166 15th Aug 2013 4:52pm
thanks mate.. Wink ... - .- -.
Post #204170 15th Aug 2013 5:10pm
Post #204181 15th Aug 2013 5:38pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Re: in car camera dvr
I like the sound of this do you have the link?
Matt
Post #204185 15th Aug 2013 5:54pm
Matt, there are a few sellers on ebay with slightly different ones ,but this is the place i brought mine..
http://www.ebay.co.uk/itm/370806447914?ssP...1439.l2649 ... - .- -.
Post #204188 15th Aug 2013 6:13pm
thanks for the pic Alistair, yours looks like its more or less dead centre... ... - .- -.
Post #204190 15th Aug 2013 6:14pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
That's a great price, way better value that the Blackvue (not knocking it as I have one) and has the advantage of being black and not silver so should be less obvious Thumbs Up I'll be interested to hear your thoughts after you have installed and tested. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #204191 15th Aug 2013 6:19pm
i connected it to the ranges power and put the video output into the ranges video in and had a fairly decent pic on the rse..its only 720p compared to the blackvues 1080p but it should be enough. ... - .- -.
Post #204192 15th Aug 2013 6:23pm
Hopefully it automatically records every time it powers up - the avert seemed a bit ambiguous.
Blackvue also has GPS so records speed & displays route/position with maps Thumbs Up
Post #204195 15th Aug 2013 6:30pm
i'm pretty sure its an auto record, it started the record counter when i temporally connected it... ... - .- -.
Post #204196 15th Aug 2013 6:34pm
