The rear brake pipes (flexi/solid) on the rear hub assemblies on my FFRR are knackered. I've got new ones & set about fitting them. The near side came off easily but the off side had been rounded off by some previous bodge merchant. Its the nut that links the cars solid pipes that was chewed & now its sheared off. No great problem there, into my workshop & out with some copper pipe as well as the brake flaring tool. Now here's the rub. The solid pipe disappears along the rear bodywork & in behind some rather large plastic covers. Do the pipes run all the way along to the abs brake block or is there a connector block in between? I also need to know if there are any unusual brake bleeding methods?
...Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
