Home > In Car Electronics (L322) > tv in rse
tv in rse
i have a hybrid tv tuner and i know the front screen is dis-abled whilst in motion but can peeps sitting in the back can watch tv on the rse when moving.. ... - .- -.
Post #203786 13th Aug 2013 2:06pm
simon1233
should be able to Stan, as long as you have the factory rse...
Post #203788 13th Aug 2013 2:15pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
They can in mine (although the signal is usually poor.....) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #203791 13th Aug 2013 2:40pm
yes its the factory rse Simon and i appreciate the signal is going to be sporadic at the best of times..thanks chaps. ... - .- -.
Post #203792 13th Aug 2013 2:44pm
Yes Stan, lots of options for rear seat passengers Discovery 4 HSE
Post #203839 13th Aug 2013 6:25pm
They can watch TV, or one can watch TV the other DVD or play their games consoles 2 of at the same time Thumbs Up
Post #203842 13th Aug 2013 6:35pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
I've just put the digital tv tuner into my 2004 Autobiography which has RSE but doesn't look factory fit (the autobiography of that era from the factory had the screens in the back of the seat, but mine has it in the headrests.
I have a DVD player powering the RSE and this has 2 outputs - one of these from the DVD goes straight to the rear screens, the second DVD input directly into the aux input on the tv tuner and then output 1 from the tuner goes to the front screen and output 2 goes to the rear seat screens. Its a little more complicated than that but the principle is correct.
That means the front screen can be either DVD or TV using the input select on the remote on the tv tuner.
Input 1 on the rear screens is always DVD - input 2 on the rear screens is what ever the front screen is set to - in motion the front screen is off but the tv tuner is still powering the back screens and whats on can still be controlled by the tv tuner remote screen.
It mostly depends on a) how many inputs you have on the rear screens and b) how many input and outputs you have on the digital tv tuner.
Hope that helps, but happy to talk through in more detail if needed (it took me a while to work it all out!) Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #203852 13th Aug 2013 7:31pm
sounds complicated, i think i'll stick to driving it and the passengers can work it out on their own... Laughing ... - .- -.
Post #203853 13th Aug 2013 7:34pm
