L322 steering sensor at fault? | |
Could a steering sensor throw up a fault when the ABS ECU is replaced / reset? Its a new issue not seen before and dont know whether its a symptom of another issue now we have a replacement ECU fitted
i had all the alarms cleared today, but shortly after driving again, the alarm returns.
Whats really odd is, if you turn ignition off, remove the keys and start again - no alarms. Until you set off.
When we look at the live output through the computer, the steering values change as the steering wheel turns, so its getting data back - but i wonder could the fault be intermittent? Or could the ABS ECU not be correctly reset?
Or, if the steering sensor is at fault, what is required to change one?
FFRR 2003 Vogue V8
