Home > Technical (L322) > Strange Noises from up front.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
turbo noise? ... - .- -.
7th Aug 2013 4:44pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1018 |
If it was the turbo, surely there would be a drop in power and the warning light would show?
7th Aug 2013 4:51pm |
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 |
Mine does it too. Wind over bottle is accurate subscription of the noise, and usually comes after lifting throttle after a squirt up a steep incline. I put it down to recycling valves dumping boost pressure. They are controlled by rubber diaphragms so similar to one way valve in your household hose pipe (if you have one) TDV8 Vogue SE 2009.
7th Aug 2013 4:52pm |
Cheers Simple1, sounds like I'm not the only one! |
7th Aug 2013 4:54pm |
