Home > Maintenance & Mods (L322) > Fitting a detachable tow bar
wanderer
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Hi All
Just a quick question about installing the detachable tow bar to a MY12. The installation instructions state to torque the nut on the bolt which attaches the bar into the armature at 300nm. My torque wrench only goes up to 135nm. I've got a 2 foot long breaker bar which I'm sure will get me to the 300nm range, but it wouldn't be a scientific process.
Could anyone advise. Should I just fit using the breaker bar, tightening to the point at which, essentially, I can't tighten anymore?
Thanks for any advice.
W
Post #202676 6th Aug 2013 5:57pm
i think the 300nm might be wrong..thats more than twice the torque for wheel nuts.. ... - .- -.
Post #202678 6th Aug 2013 6:11pm
wanderer
Stan
I've got this value from page 3 of the accessory fitting guidance on topix
http://topix.landrover.jlrext.com/topix/co...tabs=false
I may well have not understood something though.
Thanks
Post #202680 6th Aug 2013 6:15pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
300Nm on the actual towbar receiver is probably right although 300Nm is a LOT!
Post #202682 6th Aug 2013 6:21pm
wanderer
Thanks Weejock
I must be reading something wrong. If you check the link in my above post, the 2nd illustration box on Page 3 has an arrow pointing to the nut with "300nm" in the corner of that box.
Grateful for the help.
W
Post #202683 6th Aug 2013 6:25pm
this is from the workshop manual and it does say 300nm,
Post #202684 6th Aug 2013 6:26pm
Weejock
wanderer wrote:
Thanks Weejock
W
Editted my last post after I realised what you were referring too, the actual towbar armature instructions I had were wrong. 300Nm on the receiver is probably about right. I struggled with 250Nm on hub nuts before so as long as it's above that I wouldn't be too concerned.
Post #202686 6th Aug 2013 6:31pm
wanderer
Thanks guys. So basically give it a lot of force on my breaker bar should be about right!
Post #202687 6th Aug 2013 6:34pm
If you have a 2 ft breaker bar, its pretty much the same as a 60kg on the end of it......ish.
I thinks
300lb @ 1ft
150lb @ 2ft There is nothing that can't be fixed with a hammer😜😜
Post #202692 6th Aug 2013 6:44pm
