![]() | Home > Maintenance & Mods (L322) > Best way to use the boot cubby behing the right wheel arch? |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
I belie that the toggles can be replaced - email Dan and Duckworths (site sponsor) and he will tell you.
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Mine has a grey coloured plastic tray which slots into that recess. Its about 3" deep so I can use it to store some bits and pieces in it. When it stops bucketing down I'll take a photo of it and post it.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
The toggles are dead easy to replace. Simply insert and twist to lock them in place. Si. <This is my name.
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 507 ![]() ![]() ![]() |
Apologies to OP if I'm stating something he already knew but there is also a small storage compartment underneath that recess. There should be a leather tab where it meets the side wall and this flips open the lid. Would that suit your requirements? MY11 Vogue 4.4 TDV8 - "African Queen" |
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
The spaces under the boot floor on the driver side are ideal size for the set of manuals, plus other stuff. As the OP may have discovered, there are also shallower storage spaces beneath the boot floor on the left too, I keep a rope and other small things there.
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
I am surprised no one has mentioned they are great for smuggling. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
that cubby hole is ideal for a bottle jack. ... - .- -.
Or the tow bar if you have the detachable one African Bush Junkie ... in London!
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
Mine is soon to have a second battery fitted in that space. It is perfectly positioned for a short wire run up to the 100amp perm live to the rear fuse box. |
^ make a fairly tight cardboard box around the battery ,insert into hole then use expanding foam to fill the gaps.. ... - .- -.
Depends on what battery you are going to fit.
Are we both talking about fitting the battery in the above floor recess visible from the luggage area and not the recess below the floor?
