Home > Technical (L322) > My baby has no power 2003 HSE V8 feels like a 4 cylinder
flow11234
United States 2003 Range Rover Vogue SE 4.4 V8 Giverny Green
Hey guys. I brought my 03 hse RR with 109k miles. The check engine light came on and these are they codes came up. the car has no power at acceleration. once its at 70 to 80 mph If I try to step on the gas harder
the RMPS race up but the truck goes absolutely no where and the engine sound like it bout to give up. Even when I put the transmission into manual shifting the rmps go up the engine makes a funny noise.
P0159: 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0171: System too Lean (Bank 1)
P1172: Code requires manual lookup
P1300: Code requires manual lookup.
P0306: Cylinder 6 Misfire Detected
P0305: Cylinder 5 Misfire Detected
P0307: Cylinder 7 Misfire Detected
P0308: Cylinder 8 Misfire Detected
P0443: Evaporative Emission Control System Purge Control Valve Circuit
P0455: Evaporative Emission Control System Leak Detected (gross leak)
P0301: Cylinder 1 Misfire Detected
please help me so i can enjoy my 2010 autobiography facelift
can anybody help me troubleshoot and solve the issue please and thank you
[/url]
Post #202390 5th Aug 2013 4:06am
Mikey
Is the timing chain noisy? Quite a common issue on these engines with higher miles, and would cause engine misfires if worn/stretched
Post #202392 5th Aug 2013 5:49am
flow11234
Its doesn't sound any different the fewer ones that I listened to with lower miles but ill take a look into that thanks
Post #202393 5th Aug 2013 5:52am
