![]() | Home > Maintenance & Mods (L322) > MOT tomorrow |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Update when it passes |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 ![]() ![]() |
Good luck!
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Good luck on the MOT, I'm sure it'll be fine.
Failed |
Im shocked must have been something minor |
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 ![]() ![]() |
When you resume breathing I'm sure it's easily dealt with, I know I've nearly set fire to mine fifty times in the last three weeks |
Well I've just picked the loveable rogue up lol and it failed on the offside front suspension arm having excessive play in a ball joint. Booked it into the main dealer as I'm still under warranty. So maybe just maybe it'll be covered. Who knows in one of those right now I don't give a |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 ![]() ![]() ![]() |
My cars previous MOT had an advisory for some (but not excessive) play on some ball joint or other. Peculiar thing is, this year, they specifically told me they saw no such play this year? Range Rover, heal thyself! |
Wow, no wonder we bow down to them.
Yes brake pads easy Northernmonkey has some very good how tos on the brakes might even be on wiki someday I will have a wiki entry too |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 ![]() ![]() ![]() |
Rear pads dead easy, see my post in the wiki on replacing the calipers and follow the relevant bits.
Thanks I will check search the site. Shouldn't make a difference if they're brembo should it? |
It's only the fronts that are Brembo Got - 2017 SDV8 Autobiography in Loire Blue
