![]() | Home > Technical (L322) > Help non starter .(( |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
Intank Unit cankered |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
One of the two fuel pumps have failed... Check the wiki as this has been covered many times on the forum |
The remote one doesn not give inj fault message |
Needle Member Since: 07 Dec 2012 Location: Aberdeen Posts: 51 ![]() ![]() |
so the general thought is its the pump inside the tank thats gone ? |
No, the pump in front of the n/s rear wheel. remove the cover and hit it with a spanner and it should come on for a few miles
thank you |
It may well be an injector. I had exactly the same issue and it was an injector not the pump. The pump seems a very sensible place to start though. |
mmm ok so i just went out side and opened the panel , switched the ignition on and u can hear the pump running,runs for about 15-20 seconds then shuts down. it sounds like you can hear diesel getting pumped back into the fuel tank ? |
just changed the pump with a new one still a non started without easy start .((... leak off test next then .. how much is acceptable as leakage on these things as a matter of interest ? |
Fame Member Since: 01 Dec 2012 Location: Oliveira do Hospital Posts: 42 ![]() ![]() ![]() |
Same as Kurt, my one injector had packed up. Range Rover Vogue TD6 2002
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
had the same fault a while back, turned out to be the immobiliser ews fault .
when shes already running (after easy start) do you still getting injection fault displayed? |
