Home > Maintenance & Mods (L322) > Allard EGR Removal, Replacement kit
Smithy313
United Kingdom 2006 Range Rover Vogue Td6 Java Black
After searching and reading all the threads on the ERG removal, I decided to tack mine off and look how much grime was in there, I was shocked how much the was have got 40k on the clock,have cleaned it out and I've ordered the removal kit.
Post #201291 28th Jul 2013 6:29pm
its surprising how all that carbon gets in there...some members have cleaned it and refitted but its best to get rid and blank it.. ... - .- -.
Post #201302 28th Jul 2013 7:46pm
ahebron
New Zealand
Hi Smithy
I would also recommend you whip the manifold off and give it a good clean. Mine had a 5mm layer of soot inside. Beware you and everything around will get absolutely filthy. My car started blowing horrendous clouds of smoke under throttle till I cleaned the manifold.
I used engine cleaner. petrol and hot soapy water with a good supply of scrubbing brushes. Yes I know I shouldn't use petrol for cleaning but sometimes you just have to do what you have to do. Whistle
Adrian VW Amarok 2014 Highline auto
Post #201338 29th Jul 2013 9:08am
