Home > Maintenance & Mods (L322) > help please
bluearmy
England 2006 Range Rover Vogue 4.4 V8 Java Black
help please
went to check oil today only to notice my header tank has oil in it there is no water in the engine side car has been running fine no overheating is there an oil cooler on these its ajv8 just hope its not head gasket any help please Sad Sad
Post #201019 26th Jul 2013 6:12pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Not a good sign if it has oil in. Prob head gasket. You should top up with fresh coolant and inspect for leaks. Check that there is no water in the oil(looks like mayonaise in the oil cap). My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #201020 26th Jul 2013 6:25pm
mjrp
Hi
When you say your header tank has oil in it, what do you mean? Is there a sheen, like oil on a puddle, multicoloured or are you saying the header tank is full of black oil?
I have actually witnessed my neighbour topping up the oil on her car and as I approached, she was smiling smugly that she was able to do it herself, fine until I pointed out she was filling the header tank!
A little extra detail may help us diagnose a bit better for you, head gaskets most commonly reveal themselves with overheating as has been said, all the gasses combusting in the bores escape into the water jacket and heat up the coolant, water also tends to work its way into the oil causing emulsification as bluearmy says, that is normally more common than clear oil in the sump and oil in the water.
Let us know more details!
Mat
Post #201023 26th Jul 2013 6:33pm
bluearmy
hi no overheating not pressurising no mayo it looks like bayles the drink im wondering if its the oil cooler thats part of the gear box how do i check gear box oil to see if the oil has mixed
Post #201024 26th Jul 2013 6:40pm
mjrp
Well, if your dipstick is clean and the oil level hasn't dropped then it is entirely possible that your oil cooler is to blame, I haven't worked on a L322 so can't give you specifics on the gearbox level I'm afraid, I'm sure someone will be along to help you soon. I know some are sealed so there is likely to be a level bung half way up the casing but I'm just guessing.
Good luck!
Post #201030 26th Jul 2013 7:06pm
bluearmy
thanks for you reply i hope its the cooler but dont think this is going to be a cheap fix
Post #201032 26th Jul 2013 7:11pm
hoppy_70
Ebajema has had issues recently of this nature. Might be worth a PM to him for advice. This thread mentions the work he did
http://www.fullfatrr.com/forum/topic19372....box+cooler My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #201035 26th Jul 2013 7:55pm
