![]() | Home > Technical (L322) > Test viscous fan? |
GTJones Member Since: 23 Aug 2012 Location: Carmarthenshire Posts: 35 ![]() ![]() ![]() |
Hi
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
Yeh, viscous fan is on the inside. If you can spin it freely when warm then it's broke. They aren't expensive but can be a pig to get off if you don't have the tool.
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
As above, the viscous fan may just be free-wheeling when warm and not pulling enough air through the radiator.
As above the viscous unit is about £130ish or more i think depending on source.
Just to add, the details I gave were for the early FFRR so BMW engined pre facelift, I see Hoppy yours is a 2006 so fuse details may be different. I suspect the system will be the same or similar though with the electric fan assisting the viscous fan.
Ragerover Member Since: 01 Feb 2011 Location: Newcastle Posts: 220 ![]() ![]() ![]() |
Try team valley landrover there an approved garage from landrover cant praise them enough
winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135 ![]() ![]() |
The big fan at teh front, ive never heard that come on. The viscous fan i know does spin as i can see it, i will test it tonight.
