Home > Maintenance & Mods (L322) > Other caliper now binding!
Arrrgh Chaps and Chapettes,
Having had one rear caliper replaced last year the inevitable has happened, the other is now binding quite badly.
and im going away with the caravan in it tomorrow. Sods Law
what do i need apart from the caliper?
New bolts? new sealing washers for the Banjo fitting? New bleed nipple? ie does the caliper come bare?
I know how to do it just want to make sure i have everything before I Start, unfortunately for me it is too short notice i suspect to have it done under warranty in the morning.
Will do some pics Stan as i go along if its not peeing down. There is nothing that can't be fixed with a hammer😜😜
Post #200606 24th Jul 2013 6:27pm
can you not just free it up ? ... - .- -.
Post #200612 24th Jul 2013 6:31pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Are you sure it is the caliper. I had the rear pads bind up on my RR, a good clean and they have been fine for the last 4 months 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #200614 24th Jul 2013 6:36pm
Yeah last time it was off i noticed the seal was a little bit scoobied, forgot about it.
Pads should be fine as they were done about 6 months ago with the other caliper, all cleaned up etc. so pretty comfident its the caliper, have ordered one from ecp,
What brake fluid are we supposed to use, dot4? There is nothing that can't be fixed with a hammer😜😜
Post #200646 24th Jul 2013 9:08pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Everything you need should come with the calliper. Really easy to do, just bleeding is really a two man job. My 2008 is on its second set of rear calipers!
Good job the Brembo aren't that Censored !
It's literally a half hour job. Thumbs Up[/code] My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #200647 24th Jul 2013 9:13pm
I have a helper in the morning so bleeding shouldnt be a problem, have a bleed hose and jar, all the tools i need and my caliper should be a ECP at 8.00 so all being well should be able to get away on time. There is nothing that can't be fixed with a hammer😜😜
Post #200649 24th Jul 2013 9:19pm
hoppy_70
Wear glasses! You do NOT want a trip to a and e with brake fluid in your eyes.... My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #200650 24th Jul 2013 9:21pm
Im a speccy anyway, but good tip! There is nothing that can't be fixed with a hammer😜😜
Post #200669 24th Jul 2013 10:12pm
ebajema
I didn't change the bolts, just the calipers, both were replaced when the one was binding, 2 years ago. Dealer supplier the parts, the boys here did the work, no issues since. MY 2010 5.0 SC Galway green and sand interior!!
Post #200676 24th Jul 2013 11:04pm
All sorted.
Really easy, couldnt seem to get hold of the replacement sealing washers for the banjo fitting, so i cleaned up and anealed the old ones.
Took about 20 mins all in including waiting for helpermonkey to bleed the brakes,
Helped that i had all the tools and a thin adjustable to get onto the slider bolts and a brake bleed kit.
I took some pics and will post them up when i get back.
Got a remanufactured pagid caliper (casing will no doubt be gen as they exchange them) cost £86 with code ukpas25 less surcharge of 28.80incl vat when i return the old one! Bargainorama. There is nothing that can't be fixed with a hammer😜😜
Post #200822 25th Jul 2013 7:27pm
Advanced Factors
Site Sponsor
Just noticed this post, we have brand new TRW ones in stock, which are more money than you just paid, so will be adding exchange units tomorrow for the next unlucky person reading this. Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #200827 25th Jul 2013 7:46pm
