Home > Technical (L322) > IIDTool And Healthy TPMS System Live Values
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Need a favor from somone with an IIDTool and a healthy TPMS system, after changing 3 sensors (including the spare) I'm getting the check spare message despite following the 'use spare as a road wheel' guidance.
Could you please go into 'Live Values' and check the TPMS feedback, you'll notice you will get psi readings for FR FL RR RL - do you also get a value for 'spare' as I seem to be missing this?
Thanks.
Post #200138 22nd Jul 2013 9:06pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I turned off the spare in th ccf. I'll try and get values when I'm next in the car.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #200144 22nd Jul 2013 10:03pm
Katash
Was it turned off with IIDTool?
By the way my FR FL RR RL are all displaying healthy readings, I'm just missing an entry for spare - wanted to know if it shows up on anyone elses
Got a feeling that despite running the spare as a road wheel its still missing from the ID list
Post #200146 22nd Jul 2013 10:08pm
TheAllSeeingPie
Turned off with IID Tool
Post #200242 23rd Jul 2013 12:29pm
Katash
What option did you select in car configuration -> TPMS?
The options I had were
TPMS
TDDS
None
ERROR
Undefined.
Dont recall seeing an option to disable the spare monitoring.
Post #200244 23rd Jul 2013 12:42pm
TheAllSeeingPie
I can't remember it was about a year ago. I'll try and check when I do the tpms checks for you.
Post #200408 24th Jul 2013 6:18am
Katash
I presume if you have turned off spare monitoring you'll probably be missing an entry for spare like me, I need to know from someone who has all wheels monitored if spare value is shown or not - thanks for the offer tho.
Post #200432 24th Jul 2013 8:43am
Katash
Just checked mine again and found no option in CCF editing menu to turn off spare monitoring - but I am on beta software so that may be the reason.
Think I need to put spare back on as road wheel again.
Post #200509 24th Jul 2013 11:59am
T24RES
You did put the extra psi in the spare? Just a thought as I had this message until I over inflated the spare tyre.
Post #200544 24th Jul 2013 1:38pm
Katash
Yep 42psi as recommended by sticker on B pillar.
Post #200545 24th Jul 2013 1:40pm
T24RES
Sorry, I'm out of suggestions.
Post #200635 24th Jul 2013 7:43pm
Katash
Pretty sure it got confused registering due to changing 3 at once - all I need is just 1 person to tell me if their IIDTool shows the spares feedback in live values. TASP has kindly offered but his spare monitoring has been turned off so probably wont show anyway.
Heres hoping somebody can help me out.
Post #200644 24th Jul 2013 8:04pm
Katash
Dont worry guys, the GAP-Diagnostic team have stepped in to help me.
Post #200837 25th Jul 2013 7:32pm
SteveMFr
Site Sponsor
Yes - saw the thread only a day or 2 ago. Sorry.
We have supplied Katash with special beta SW containing the spare in the live values. Simple reason why it wasn't there before: the spare tires in our development L322s were not monitored (for whatever reason). And in contrast to other diagnostic systems, we try very hard to make sure every function we add to our system can be used on the vehicle and is tested before we release to the public.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #200972 26th Jul 2013 12:59pm
Katash
Further information regarding this issue
For some reason the ECU is reading the spare as about 15.2psi so now I understand why the warning is there, however the current spare is the original FR wheel and was confirmed by 'live values' to be reading 36psi only yesterday - I know there is not a leak so this is obviously an incorrect reading - issue was still present when the spare was exchanged with the RR @ 42psi too - so there seems to still be a conflict on the actual spare sensors 'ID'
Have completely removed spare wheel from vehicle to see if I can effectively 'null' the value then start from fresh again.
Yet again excellent customer service from GAP-Diagnostics Thumbs Up
Post #200981 26th Jul 2013 1:53pm
