![]() | Home > Technical (L322) > Huge coolant leak with air con running/ pic attached |
totally normal, dont worry, its the drain of from the condesor V8 facelift Range Rover Autobiography 22" wheels.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
Possibly a combination of the very hot weather and the air con condenser working extra hard to cool the air? Got - 2017 SDV8 Autobiography in Loire Blue
edward.barry Member Since: 26 Aug 2011 Location: Cavan Posts: 37 ![]() ![]() ![]() |
Agreed, no worries, it's the normal operation of the AC at work, you're not losing anything vital. regards Ed 0-60 takes 5 and a half seconds...and about 17 gallons of fuel.... Current fleet 2005 RR td6 1997 300 Discovery 2005 Subaru Legacy Outback (the wife's) 1981 2.5 Opel Commodore |
jumbocar Member Since: 08 Jul 2013 Location: London Posts: 22 ![]() ![]() |
Wow really? It really is pouring down heavy while the air con is running- non stop- feels, smells, like water- really cold though... |
you will see it on all AC, dont think its can be as bad as a comercial system as the can suffer blocked or cracked drip trays, this is when it starts dripping from the corners ect. but you have no worries,what did they charge you for the regas..
Thanks fellas really appreciate the speedy replies
Your AC is also a dehumidifier so all of the cold water is perfectly normal... Your kitchen fridge will have a drain hole in the bottom and the water drips onto a hot part of the motor which makes it evaporate hence you don't see the water at home on the kitchen floor! All perfectly normal |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
This will increase with humidity as well, which is why you are noticing it more now its hot(ish) My Previous RR's!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Agreed looks quite a lot, but it is;
